Old 07-18-2011, 05:38 PM   #1
jim1932
jim1932's Avatar
Default Open trailer specs?
What are the specs I am looking for for a dependable trailer to haul a model B tudor. What are these going for used. Recommendations + - between metal and wood and those two metal ramps and open in the middle type. Not looking to go cheap but don't want to overkill it. I will only use it three or four times a year (unless a B will fit in a horse trailer...LOL). Any issues with hauling with a half-ton with electric brake set up?
jim1932 is offline   Reply With Quote
Old 07-18-2011, 06:56 PM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: Open trailer specs?
Jim, I have a new Featherlite aluminum trailer that I have pulled to Abilene, Ks to rescue my '50 Ford and I hauled my '40 pickup to Saratoga Springs last week, both with a '99 F-150, no problems.
Cecil/WV is offline   Reply With Quote
Old 07-18-2011, 08:34 PM   #3
jim1932
jim1932's Avatar
Cecil, what is it rated at? I assume I need dual axles?
Old 07-18-2011, 09:33 PM   #4
Cecil/WV
Cecil/WV's Avatar
Jim, If you are coming to the club meeting tomorrow night, you can look at it because I am delivering a pickup to my daughter in Baltimore tomorrow afternoon and returning to the meeting on the way home. I think it is 7000 #, without looking at the label.
Old 07-18-2011, 11:02 PM   #5
Dick Webber
The BigBee trailer I have used for 25 years for Model A, T, V8, and general hauling is a steel, square tube, tandem axle with 5 lug wheels, brakes on 1 axle, and wood floor, straight, no beavertail. Uses heavy removable steel ramps. It is 16' long and 6 1/2' wide.This trailer has side rails which are 18" high, tapered to the rear. The side rails are a plus for securing and containing irregular loads, but limit you hauling a wide vehicle and sometimes you have to crawl out a window. Not a problem with Model A & T however. Might not haul a long Chevy Suburban, but I have hauled large vehicles with it. I recommend breakaway brakes. I intend to add brakes for the second axle. Square tube steel is less expensive than aluminum, much more substantial than cheap angle iron trailers. Pulls well and does not wear tires. Get 8 lug wheel axles for heavier loads, but this is fine for car hauling.
When you have a trailer you never run out of friends.
Works for me!
Dick
Dick Webber is offline   Reply With Quote
Old 07-19-2011, 09:55 AM   #6
jambottle
jambottle's Avatar
With new enclosed trailers going for less than $1000 more than an open trailer.They give you security plus free storage.Just do your homework. you can add a 5 foot v nose on the front for extra $500.Great for storage,winch or even a couple of bunks.Just something to consider.Square tubing walls is something to look for.
my mother always said:you got a champagne taste and a beer pocketbook!
jambottle is offline   Reply With Quote
Old 07-19-2011, 10:08 AM   #7
Cecil/WV
Cecil/WV's Avatar
Jim, Here's the data plate.
