Old 03-10-2019, 02:47 PM   #1
51woodie
51woodie's Avatar
Default 46 Coupe Rear Seat Removal
How do you release the seat portion of the back seat? I tried pushing down and back to unhook the seat but no go. Not pushing hard enough? Are there bolts or screws I didn't find?
51woodie is offline   Reply With Quote
Old 03-10-2019, 03:32 PM   #2
TJ
TJ's Avatar
Default Re: 46 Coupe Rear Seat Removal
You are probably not pushing hard enough. No bolts or screws to my knowledge except those that hold the backrest at the bottom
Old 03-10-2019, 03:42 PM   #3
Phil Gillespie
Phil Gillespie's Avatar
Have a 46 Mercury Coupe and expect this would be the same?
Intend to remove rear seat also. Back rest out first followed by seat cushion next? both sections are just clipped in place?
Sorry not trying to hyjack.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 03-10-2019, 03:47 PM   #4
TJ
TJ's Avatar
The Merc seat should come out the same way. Bottom first and then the backrest. The back rest should have some metal tabs on the bottom that are bolted in place to the floor pan.
Old 03-10-2019, 07:25 PM   #5
Phil Gillespie
Appreciate clarifiation on that. Bottom first to access lower tabs for back!
Phil NZ
Old 03-10-2019, 08:02 PM   #6
paul2748
paul2748's Avatar
Yes - bottom first. Pull up the front of the bottom and slide out. Below the back cushion you will see the tabs with a bolt. Undo the bolts and pull up. That is the way my convertible is.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-10-2019, 09:02 PM   #7
51woodie
51woodie's Avatar
Thanks for the responses. Push back then up is what I suspected, but I guess the -10C weather is causing the seat padding to be too stiff to compress and not allowing the seat move back to unhook.
Old 03-11-2019, 09:41 AM   #8
waterboychuck
waterboychuck's Avatar
Unscrew/bolt the bottom of the back of the rear seat and then push up as there are two tabs that hold it in place.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
