12-18-2021, 04:34 PM | #1 |
Fenton Headers
Fenton headers on a 1940 24 stud. One bolt will not thread. I give up. Not my car but doing an engine change for an elderly friend. I spent way too much time trying to get one bolt to thread. The design looks like the designer was on crack. POS Fenton headers they are...
12-18-2021, 04:49 PM | #2 |
Re: Fenton Headers
Front bolts are 7/16-16, all the rest are 3/8-16. Welcome to Ford Flatheads.
Alan |
12-18-2021, 04:53 PM | #3 | |
Re: Fenton Headers
12-18-2021, 05:30 PM | #4 |
Re: Fenton Headers
This fellow may have a set of off shore knocks off. The instructions should read due to accumulated tolerances some adjustment is required.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-18-2021, 05:50 PM | #5 |
Re: Fenton Headers
12-18-2021, 06:00 PM | #6 |
Re: Fenton Headers
12-18-2021, 06:21 PM | #7 |
Re: Fenton Headers
You are correct. My bad.
Alan |
12-18-2021, 06:29 PM | #8 |
Re: Fenton Headers
Ran into the same problem with engine holding [mount] exhaust plate-Some adjustment of holes required Newc
12-18-2021, 10:35 PM | #9 |
Re: Fenton Headers
I have a set, bought from a swap meet, but new-ish looking, I assume speedway Chinese mfr, and they fit just fine. Got a rat tail file?
12-19-2021, 12:48 AM | #10 | |
Re: Fenton Headers
Just be sure it's a USA-made rat-tail file! Otherwise, make'm funny holes! DD . |
12-19-2021, 02:09 AM | #11 |
Re: Fenton Headers
I’m in before the hammer!
Alan |
