Old 12-08-2019, 06:28 PM   #1
fred93
fred93's Avatar
Default 29 Tudor kick panels
How many screws are used to attach the kick panels. When I got the car the kick panels were missing, so I have no idea how they are attached. I have looked at several photos and as near as I can figure it looks like 5 places--see photo. But I could be wrong!
Why is there never enough time to do it right, but always enough time to do it over!!!
fred93 is offline   Reply With Quote
Old 12-08-2019, 06:57 PM   #2
Dean Lemoine
Dean Lemoine's Avatar
Default Re: 29 Tudor kick panels
I think your numbers 1, 2 and 5 are for screws holding the kick panel. Numbers 3 and 4 are for the door check strap bracket, which also hold the panel.
Dean Lemoine is offline   Reply With Quote
Old 12-08-2019, 09:33 PM   #3
fred93
fred93's Avatar
Thanks for your reply--I assume that all 5 screws should be #10 fine thread?
Old 12-08-2019, 10:08 PM   #4
Neil Wilson
Neil Wilson's Avatar
For the 82-A closed cab - #1, 2, 5 are #10 x 3/4" sheet metal screws (oval head and nickle plated). Used with finish washers (.224 ID x .580 OD). #3, 4 are #12-24 oval head and nickle plated.
I believe all 1928/1929's are the same.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 12-09-2019, 09:50 PM   #5
fred93
fred93's Avatar
Thanks for the reply. I will have to look a little closer. I thought that I saw threads in the holes, but I could be wrong. There is a lot of paint in the holes so I'll need to double check.
Old 12-10-2019, 06:44 AM   #6
Gary Karr
Gary Karr's Avatar
Also, you will need the retaining clips for the upper forward corners. They have a large hole in them for a small rubber gromet for your electric wiper wire. You will use only one per side.
Gary Karr is offline   Reply With Quote
Old 12-10-2019, 07:48 AM   #7
Dean Lemoine
All of mine (29 Tudor) were threaded. #10x32 on 1,2 and 5 and 3 and 4 were
1/4x20.
Old 12-17-2019, 09:56 PM   #8
fred93
fred93's Avatar
Thanks Gary'
I have those. I am just trying to figure out what type of screws hole the kick panel to the pillar. I am aware that the two screws that attach the door check strap to the pillar are #10 fine thread, but I am not sure about the others. Right now there is a build up of paint on the metal tabs where the screws attach so I can't really tell if they are threaded or not. I just need some time to check it out.
Old 12-17-2019, 11:12 PM   #9
SteveB31
SteveB31's Avatar
Door strap screws are not #10, they are 12/24
SteveB31 is offline   Reply With Quote
