Old 10-30-2019, 06:29 PM   #1
AR
AR's Avatar
Default Gas Smell Inside
I started to notice that every time I fill up the gas tank on my 56 Merc wagon I get a strong gas smell inside the car. I have checked for gas leaks from the carburator back to the gas tank with nothing showing up. Does anyone know what the problem might be?
Thanks
AR
AR is offline   Reply With Quote
Old 10-30-2019, 08:03 PM   #2
paul2748
paul2748's Avatar
Default Re: Gas Smell Inside
Did you look where the sender is? It can leak there
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-30-2019, 08:55 PM   #3
AR
AR's Avatar
I have not check it but I will now.
Thanks for your input.
AR
Old 10-30-2019, 08:56 PM   #4
Alaska Jim
Alaska Jim's Avatar
I had a small leak on the hose on the metal filler neck tube that goes from the tank to the outside of the car. it was leaking down near the tank and could not bee seen, until I pulled all the carpet, and trunk liner from the trunk. just a thought. This was on my '51 Merc.
Alaska Jim is offline   Reply With Quote
Old 10-31-2019, 12:56 AM   #5
50fordcoupeman
50fordcoupeman's Avatar
When I got my car, it had a seep around the sending unit access hole. Mostly leaked only upon gas fill up. Hope this helps.
50fordcoupeman is offline   Reply With Quote
Old 10-31-2019, 12:55 PM   #6
poolplayer1
I had the same problem you have with my 55 wagon. In my case,it was a bad gasket at the sending unit flange. Put a new gasket in it and the small was gone.
poolplayer1 is offline   Reply With Quote
Old 10-31-2019, 01:01 PM   #7
Ole Don
Ole Don's Avatar
Yup, the sender gasket is dried up. Never park inside with a full tank and it won't bother you. Removing the tank is a bear the first time.
Ole Don is offline   Reply With Quote
Old 11-03-2019, 12:38 PM   #8
Ford56
Ford56's Avatar
I agree 100%; if you can leave about a gallon or two out of a "full tank", it could make a difference in the smell. Worked for me.
Ford56 is offline   Reply With Quote
Old 11-03-2019, 11:23 PM   #9
Daves55Sedan
Daves55Sedan's Avatar
It's a good bet that the sending unit cork gasket is at fault, because there is really nothing besides that little round cover-plate separating the sender from the hole thru the floor for the sending unit. So, you'd definitely get the smell.
Another thing to check is the rubber hoses that connect the filler neck and vent tube to the tank. If your gas tank is overfull, gas may be encroaching upon those hose connections. If the worm-gear clamps are not tight enough, some gas might leak, but I don't think you'd smell it so much inside the car.
Old 11-06-2019, 11:32 PM   #10
AR
AR's Avatar
Thanks everyone for your comments. I checked the sender unit gasket and it was dry. I will check the hoses at the filler tube. I also will drive the wagon and get the gas level down to see when it stops smelling.
Thanks again
