Old 10-28-2018, 09:29 AM   #1
37 Coupe
37 Coupe's Avatar
Default Copper head gasket or best Kevlar?
Am I correct in thinking that the Model A engine was built using copper head gaskets? I never had much luck with copper on a couple V8 Ford engines so I thought I would go with the Best gasket that Brattons sells,Kevlar and graphite. Anyone successfully use this gasket? I am having second thoughts because of a post from an experienced engine rebuilder who uses only copper.Brattons sells a Felpro copper gasket but only says it has a gray material in the middle not what kind.A better copper gasket available preferably USA?
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 10-28-2018, 09:49 AM   #2
katy
katy's Avatar
Default Re: Copper head gasket or best Kevlar?
Back in the '50s I did a LOT of work on flathead V8s, the available head gaskets were either copper clad or steel clad. We always used the copper clad ones with no sealer and never had a problem. You have to be sure that both the head and the block are perfectly clean and that the gasket is installed w/the proper side up.
Old 10-28-2018, 11:21 AM   #3
30 Closed Cab PU
More info on the Ford Garage.
Home page http://www.fordgarage.com/
Head Gasket info http://www.fordgarage.com/pages/ABcy...asketguide.htm
Do not see info on a solid copper gasket. Has info on what was originally used.
Old 10-28-2018, 11:45 AM   #4
Jim Brierley
I prefer copper as they are easier to remove and can often be re-used. I've never had a problem with them sealing. Best makes their #509 in copper or some kind of material that works well but is a pain to scrape off when changing heads.
Old 10-28-2018, 12:03 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
The Secrets of Speed Society recommends the Best Graphtite gaskets with no sealant. I have never had a problem with these gaskets either with Y-Blocks or Model As. They recommend 55 ft lbs max.
http://www.secretsofspeed.com/gaskets.htm
Old 10-28-2018, 02:43 PM   #6
john in illinois
john in illinois's Avatar
Whichever Best gasket you use,they reccomend copper coat spray. I use the grapftite on my A and Flathead.
John
john in illinois is offline   Reply With Quote
Old 10-28-2018, 05:44 PM   #7
MAG
MAG's Avatar
Back when Brumfield was making heads he would not honor warranty if any head gasket was used other than the Copper FelPro 7013.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 10-28-2018, 11:51 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
And I agree with Larry.
Old 10-29-2018, 08:48 AM   #9
katy
katy's Avatar
Don't think that I've ever heard of a solid copper head gasket. If there was one it would have to be pretty soft copper.
Old 10-29-2018, 09:06 AM   #10
30 Closed Cab PU
Thanks for correcting me, was a misunderstanding on my part from a long ago previous post.
Old 10-29-2018, 10:54 AM   #11
P.S.
I recently installed a Best brand kevlar (they call it graphite) head gasket on a Model A. I followed all directions exactly. No water seepage, however when pulling a hill in 3rd gear at 45 MPH or so, the combustion gasses are getting into coolant and blowing the water out the radiator overflow.
Yes, I have re-torqued it (read above where I followed ALL directions). The block/head are flat.
Going back to copper gaskets. No problem with those.
P.S. is offline   Reply With Quote
Old 10-29-2018, 04:31 PM   #12
37 Coupe
37 Coupe's Avatar
Kinda what I wanted to hear or didn't want to hear. Copper sprayed with Ultra Copper? I only want to do this once.
Old 10-29-2018, 04:51 PM   #13
Dick Steinkamp
Dick Steinkamp's Avatar
Are you sure that is what is happening? Have you had the coolant checked by a radiator shop for combustion gasses? Could it be the motor is getting a little hotter pulling the hill, the water warms up a little more and expands a little more and comes out the overflow?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 10-29-2018, 05:14 PM   #14
30 Closed Cab PU
Could also do radiator exhaust test yourself. $45 dollar Napa Block test kit.
Radiator issue? -How old is it?
- Has it been flushed and back flushed recently?
- Empty it, block the upper and lower openings, should hold 1 1/2 gallons.
- Could be partially plugged or if old fins not making good contact with tubes.
- How old is the radiator, fins/inch, rows ?.
- When run and and stop/turn off, does it burp coolant? (running hot?)
Last edited by 30 Closed Cab PU; 10-29-2018 at 05:15 PM. Reason: corrected s[pelloing, conttent
Old 10-29-2018, 09:22 PM   #15
1crosscut
1crosscut's Avatar
When using the spray type copper products on head gaskets I do three light coats and allow plenty of time between coats to let the solvents flash off making it very tacky.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-29-2018, 09:47 PM   #16
P.S.
I know you guys are just trying to be helpful, and I thank you.
However, I am most positive that it is combistion gases blowing into the coolant. No question. That is fact. Otherwise, I wouldn't have said it.
Fordbarn forum can be a blessing and a curse at the same time. Someone comes on here and says their steering is loose and there is always someone quick to tell them their timing is off.
Old 10-29-2018, 10:21 PM   #17
quickchange
quickchange's Avatar
We produce a copper one that is sealed around outside edge so no weeping down the block , can also be used on B engines too . Wet & cold in NZ plus 6.7 earth quake few mins ago.
quickchange is offline   Reply With Quote
Old 10-29-2018, 10:48 PM   #18
Gary WA
Gary WA's Avatar
Copper!!!! Larry Brumfield knows!!!
www.whidbeymodelaclub.com
Old 10-30-2018, 04:25 AM   #19
Bruce of MN
Bruce of MN's Avatar
I sure wish there was a firm consensus!
https://www.fordbarn.com/forum/showthread.php?t=251825
Old 10-30-2018, 08:22 AM   #20
katy
katy's Avatar
To each their own.
