04-25-2017, 12:47 PM | #1 |
Universal joint lubrication
Putting the rear end back in my '34. The universal joint seems to be lubricated with transmission gear lube. Is this correct or is there another way to get grease or lubricant to the U-joint?. I see that there is a grease fitting but that looks to lube the bell connection and not the u-joint. Thanks, Don
04-25-2017, 01:29 PM | #2 |
Re: Universal joint lubrication
Use John Deere Cornhead grease and it can be found in tubes at most any JD dealer. When I added the grease I pack the U-joint cavity with grease prior to final assemble and then topped it up through the grease nipple.
04-25-2017, 01:55 PM | #3 |
X2, ....exactly what I do.
04-25-2017, 04:34 PM | #4 |
Is the JDCG OK for the transmission? I think that excess grease pumped in the U joint housing goes into the transmission, The seal on the driveshaft would keep it from going that way. I don't think there is a seal on the back of the transmission.
04-25-2017, 04:42 PM | #5 |
No the grease will not migrate into the transmission I've used it in my cars for years and have never had that problem.
04-25-2017, 05:42 PM | #6 |
04-25-2017, 05:47 PM | #7 |
John Deere lists two types of cornhead grease: one for high speed gearboxes and the other for low speed gearboxes. I imagine the high speed grease is best for u-joints and the low speed for steering boxes.
04-26-2017, 01:15 AM | #8 |
Don't know if the '34 tranny is designed this way but my '47 tranny has a slinger on the tranny shaft at the rear of the tranny instead of a seal. I understand the design intention is that some tranny gear oil (i use StaLube 95w for easy shifting) gets into the U-joint to slop around and lube it, and the grease fitting on the outer U joint primarily lubes the double clam shell because they move independently. Then there's the seal in the torque tube that, if working, keeps any tranny gear oil from heading into the banjo.
I check and change my tranny gear oil and zap the clam shell with the grease gun when scheduled. I find gear oil inside the U joint chamber and have not had any problems with the U joint to date. |
04-26-2017, 01:27 AM | #9 | |
04-26-2017, 12:40 PM | #10 |
I think the grease is ok ,but if the trans runs low on oil , may cause problem with u joint. Should check if leaking often.
