02-13-2023, 03:39 PM | #1 |
V-8 Sixty oil pump replacement gear aluminum
City:
Wallingford
State:
Conneticut
Price:
85.00
The aluminum gear includes the mounting hardware. The gear replaces the stock phenolic gear which is usually and the stock aluminum gear. The gear is easy to mount all you need to do is remove the stock rivets holding the original gear on. Place the new gear on the original pump gear flange the mounting hardware is now grade 8 allens. Price is $85.00 this includes shipping in the USA. Please send me a message if interested. Thanks
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
