04-16-2022, 04:51 PM | #1 |
Converted GM three speed to fit Early Ford chassis
City:
Wallingford
State:
CT
Price:
1500.00
The transmission output shaft was converted for the Ford 6 spline universal joint and the rear has the correct bell and mount so the torque tube will bolt right up the stock Ford universal joint which is included. The overall transmission length match's the original Ford transmission exactly. The Indy shifter and linkage move the gears easily. The gear ratios are listed inside the bell housing 250 in first and 150 in second and of course third which is 1 to 1. Also included is the emergency brake handle mount on the right side of the case. Overall if your looking for a very strong replacement transmission that will fit the original space of the stock Ford three speed perfectly without moving the engine this will do it. Competing at TROG ,Pine Tree Jamboree, or just having fun side stepping the clutch this transmission will take more abuse than the early Ford three speed for sure. I learned this conversion was being done by a fellow from upstate New York at one time he did many of them years ago here's one that's ready to go. If you would like more pictures info or would like to talk to me about this please send me a PM. I'm asking $1500.00 The cost to ship if not picked up is unknown but arrangement's can be made if shipping is required.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
