12-13-2016, 11:19 PM | #21 | |
Re: Fuel Filter Restriction
12-13-2016, 11:25 PM | #22 |
12-13-2016, 11:40 PM | #23 |
Ain't it the truth.
All steel from pedal to wheel |
12-13-2016, 11:45 PM | #24 |
#10 post by 29er is the exact thing I did, with the magnet trick. Never a problem with fuel again.
12-14-2016, 02:07 AM | #25 | |
I had a cheap napa in line filter, which would work until you tried to pull a hill under full throttle. I got rid of it, installed a dirty leg, and flushed my tank. |
12-14-2016, 10:11 AM | #26 |
Appears the problem with a good dribble is it works until one mashes on the accelerator to pass a line of four (4) or so slow moving cars and one's Model A stalls because the driver finds his get up & go ...... has got up & went. Seems similar to a guy with partial artery blockage "sitting" in his rocker on his front porch; then the young good looking mail lady toots her horn for him to sign for a package 35 yards away, way out front, by the mail box. This 86 year old guy, (same age as his Model A), looks at her big boobs, takes off running wide open, and runs out of breath on his 15 yard line. Unless Model A parts suppliers start offering something similar to Model A Viagra Fuel Tank pills, seems wise to try to get as close to Full Fuel Flow prior to departure on a long Model A tour. Hope this blood flow comparison helps Model A owners to remember some of the disadvantages of Model A dribbles. |
12-14-2016, 05:05 PM | #27 |
12-14-2016, 07:15 PM | #28 | ||
What the OP stated was that he installed an in line fuel filter and now has to richen his mixture at the GAV in order for the car to run the same as it did before the filter. He felt reduced fuel flow to the carb could be the reason. My point is that these two things (possible reduced fuel flow and the need for a richer mixture) are not related. If the fuel flow is LESS than that required by the engine, the carb float bowl will eventually empty and the engine will quit running. No amount of making the mixture richer will stop this from happening. This is true for a partial blockage that is less than the overall requirement of the engine. It is also true for an intermittent blockage, or a blockage that is "on the bubble" and that a greater fuel requirement of the engine (ie...big pull up hill) will exceed the amount of fuel delivered. If there is a reduction in fuel delivery but it is still sufficient to keep the float bowl filled under all conditions, there would be no change needed in the GAV. To the carb, the fuel level in the bowl looks exactly the same as with full fuel flow. If there is a reduction in fuel delivery that is NOT sufficient to keep the float bowl filled under all conditions, the fuel bowl will empty and the car will quit running. No amount of fooling with the GAV will prevent this.
