05-03-2018, 09:54 AM | #1 |
35 V-8 stud instlation
any special sealant to put on studs in my 35 V-8 ?
Their several thread inserts . |
05-03-2018, 11:17 AM | #2 |
Re: 35 V-8 stud instlation
Yes - I always use a good coating of PTF based stud sealer . . . ARP makes some and it is good stuff. Also, coat the sides of the studs with anti-seize before you put the heads on.
https://www.jegs.com/i/ARP/070/100-9904/10002/-1 Good luck |
05-06-2018, 02:08 PM | #3 |
GM has a Teflon based sealant to use of Studs that go into the water jacket. Not a tape but but kinda of a paste, comes in a tooth paste type tube. Can't remember the P/N number for it at the moment.Should be able to get it at any GM dealer.
05-06-2018, 03:37 PM | #4 |
