Old 03-29-2018, 04:14 PM   #1
chap52
chap52's Avatar
Default '52 F1 for sale or partial "Model A" trade
City: Marana
State: AZ
Price: 22500
RECENT MODIFCATIONS:
2015 New Ivory Acrylic Urethane paint. The original flatbed, which was all framed in wood was replaced with a custom built 2x4 metal tubing frame. Both the bed, sideboards and running boards were all redone in redwood and new metal bed strips were installed. All the wood received six coats of Cabot’s Satin Spar Varnish.
New pistons were added in June 2016, new clutch, pressure plate and TO bearing in 2017
ENGINE
180 Degree Thermostats, Modern One-Piece Front Oil Seal, New Pistons & Rings, Rod, Main and Cam bearings. Hollow adjustable Johnson style lifters, Howard M-6 ¾ cam, Valves, Valve Guides, Springs and Clips, Graphite Head Gaskets, Full Flow Oil Filtering System, Melling Type High Volume Oil Pump, GM Distributor from Bubba's Speed Shop, 2700CFM, Hurricane Air Conditioning Package, Thermostatically Controlled 12-volt Ice Box Cooling Fan System.
FUEL SYSTEM
Offenhouser dual intake, Dual Holly 94 Carburetors Rebuilt by Go Cats Speed Shop, Electric Fuel Pump, Fuel Pressure Regulator, 14 Gallon Gas Tank Installed Under Bed with Pop-Up Gas Filler.
ENGINE COMPARTMENT
New Water Pumps, Speedometer Cable & Drive Gear, Hedman Turbo Mufflers, Red's Headers, Custom Tail Pipes, Radiator Recovery Tank, New Radiator, and New 12-volt Battery.
ELECTRICAL
Ron Francis Express 21 circuit 12 Volt Wiring System, 100-amp Single Wire Alternator, Ignition Switch, Push Button Turn Signals, Under Hood Light, Dome and Under Dash Interior Lighting, Battery & Ground Cables, Parking Light Assemblies, 12 Volt Windshield Wipers from New Port Engineering, Tail Lights, Voltage reducer for using stock fuel & Amp. gauges, Dual Temp Gauges, Oil Pressure Gauge, Boss 200 Watt CD/Radio Combo, 6x9 Dual Voice Speaker, (2) Tweeters in door posts.
___________________________
BRAKES & SUSPENSION
Tie Rod Tube and Ends, Spindle Bolts, Steering Stabilizer, Front Wheel Bearings, All Wheel Cylinders, All Brake Shoes, Rebuilt Master Cylinder, Shocks, Rear Leaf Spring Shackles, Bolts and Pins, Spring Bushings.
INTERIOR
Total Cab Sound Dampening Insulation, carpet, Headliner & Cab Panel Kit, Velour Bench Seat Cover Kit,
DOORS, GLASS & BODY
Door Glass Runs, (1) Window Regulator, (1) Door and Rear Window Glass, All Glass and Cowl Vent Seals, Vent Window Locks, Armrests, (3) Seat Belts, Polished Aluminum Ford Step Plates, Custom 2x4 Steel Tubing Flat Bed, Redwood Bed, Running Boards and Side Boards, Metal Bed Strips.
WOULD CONSIDER PARTIAL TRADE FOR DRIVEABLE 29-31 FORD "MODEL A" TUDOR
SERIOUS INQUIRIES ONLY - NO SOLICITORS
Call Richard (520) 407-6075 or text (765) 667-0278 with e-mail for more photos.
chap52 is offline   Reply With Quote
Old 10-10-2018, 04:34 PM   #2
chap52
chap52's Avatar
Default Re: '52 F1 for sale or partial "Model A" trade
Sold
