Old 03-11-2020, 06:06 PM   #1
jrvariel48
jrvariel48's Avatar
Default 8RT Oil Pan and starter plater
I have a 8RT starter plate and pan on my 8BA. I went on Van Pelts site and I'm missing some pieces. The main part is 8RT-6410 which looks like it bolts up to the block. Is that correct? Is this part and all the seals & bolts available?
Thanks, Joe
jrvariel48 is offline   Reply With Quote
Old 03-11-2020, 11:45 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: 8RT Oil Pan and starter plater
It does bolt up into the block. The 2 long bolts replace the 2 normal pan bolts straddling the rear seal. 6410 is NLA, as far as I know, but the rubber seals that it carries (to shield the short section of crank behind the seal in the pan) are available, I think from Mac VP.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-12-2020, 03:09 AM   #3
jrvariel48
jrvariel48's Avatar
Thank you Ross, I'll check it out.
Anybody got one??!!
Old 03-12-2020, 07:32 AM   #4
Mac VP
Mac VP's Avatar
We have the 6410, the 6424, and the 6425.......all are sold separately.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-12-2020, 03:56 PM   #5
jrvariel48
jrvariel48's Avatar
Thank you Mac! Just put the order in!
Old 03-12-2020, 03:56 PM   #6
jrvariel48
jrvariel48's Avatar
Anyone have the bolts or an idea for a replacement?
Old 03-12-2020, 04:33 PM   #7
tubman
tubman's Avatar
I'd start at the local hardware store.
Old 03-12-2020, 05:47 PM   #8
jrvariel48
jrvariel48's Avatar
Does anyone know the thread size?
Old 03-13-2020, 12:58 AM   #9
Overkill-F1
Overkill-F1's Avatar
5/16"nc, 3/4" longer than the holes in the shield should be right.
Terry
Overkill-F1 is offline   Reply With Quote
Old 03-13-2020, 03:03 AM   #10
jrvariel48
jrvariel48's Avatar
Thanks Overkill!
