Old 04-19-2021, 12:08 PM   #1
Topher5150
Default 46-48 Ford hood alignment
What is the best way to line up the hood on the 46-48 Ford cars? I'm just kind of mocking things up right now and I have to push down in the back to get it close enough to latch and the hood sides are really close to the cowl.
Topher5150 is offline   Reply With Quote
Old 04-19-2021, 12:29 PM   #2
woodiewagon46
Default Re: 46-48 Ford hood alignment
We just discussed this on another site. If you can get a copy of the May/June, 2009 issue of the V-8 Times there is an article with pictures on how it's done. If you can't locate a copy I can snail mail a copy.
woodiewagon46 is offline   Reply With Quote
Old 04-19-2021, 01:50 PM   #3
FortyNiner
FortyNiner's Avatar
The article that woodie mentioned is the best reference. Lacking that, most of the adjustment is at the cowl - specifically the bolts that extend under the dash area. Things work a bit opposite of normal meaning that moving things down tends to raise the fit and vice-versa. You also may need to adjust the fenders as part of the process.
Old 04-19-2021, 03:10 PM   #4
Topher5150
Even if you send it through the copy machine that would be appreciated. If you send magazines via USPS it's like $2 to send "media". I can send you my address. Thanks
Old 04-19-2021, 03:11 PM   #5
Topher5150
What do I do about the pinching on the sides of the cowl? Can I just bend it back without affecting anything else
Old 04-19-2021, 03:23 PM   #6
meric42
meric42's Avatar
I have a high resolution Hood Alignment Instructions document that is too big to post here, send me your email address and I can send it directly to you.
Alternatively here's a link to the document:
http://marksfordparts.com/articles/a...y-mark-kicsak/
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 04-19-2021, 05:13 PM   #7
FortyNiner
FortyNiner's Avatar
QUOTE=Topher5150;2008821]What do I do about the pinching on the sides of the cowl? Can I just bend it back without affecting anything else[/QUOTE]
Thanks meric42!
Can you share a picture or two, Topher?
Old 04-19-2021, 06:53 PM   #8
Topher5150
Thanks for the help guys but I have one question. The article talks about two bolts not mine has three
Old 04-19-2021, 07:07 PM   #9
FortyNiner
FortyNiner's Avatar
Three bolts where? On the cowl? On the hood?
Old 04-19-2021, 07:23 PM   #10
Topher5150
On the cowl
Old 04-19-2021, 07:43 PM   #11
Topher5150
Nevermind helps if I read the whole thing
Old 04-19-2021, 09:54 PM   #12
fordor41
fordor41's Avatar
I had just the opposite problem on my '41 Fordor. the hood sides were way out away from the cowl. After years of messing with it I removed the hinge springs and it fit perfectly. tried all the tricks and NOS hinges. went with a prop rod. A friend of mine painted his '47 and when we attempted to install the hood, it hit the cowl in the center and sides were 3" too high!
fordor41 is offline   Reply With Quote
