Old 03-24-2019, 07:48 PM   #1
nick c
Default radiator mounts for 29 ccpu
Could someone tell the thickness of the rubber radiator mounts.
thanks
nick c is offline   Reply With Quote
Old 03-24-2019, 08:13 PM   #2
Jim Brierley
Default Re: radiator mounts for 29 ccpu
Not very thick, maybe 1/8"???
Jim Brierley is offline   Reply With Quote
Old 03-25-2019, 06:02 AM   #3
Joe K
Joe K's Avatar
In October 1929 the relative position of the flat area where the radiator mounts was changed "downward" in anticipation of the new body styles. As an interim fix, Ford added a square washer to "build up" this area and present the original 1928-29 mounting dimensions. At least until the earlier body styles had been used up.
This is written up in the Service Bulletins.
The 29CC and RPU pickup continued to be made until May 1930, with the 1929 pattern truck bodies made after 1930 or so being fitted with 1930ish type quarter turn gas caps. The so called "transitional" tank.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-25-2019, 06:56 AM   #4
ericr
ericr's Avatar
Joe K, it is kinda interesting that the Service Bulletins did not come out and state why the change was made. obviously the Company did not want people blabbing that a new body style was in the offing, fearing that sales would drop in anticipation.
ericr is offline   Reply With Quote
Old 03-25-2019, 07:37 AM   #5
Railcarmover
its where you can play with height to get your hood line correct.
Railcarmover is offline   Reply With Quote
