01-30-2012, 11:42 PM | #1 |
Dual MC for 39 pedal set
Can anyone ID a specific part number for a dual MC that fits a 39 pedal set?
01-31-2012, 12:05 AM | #2 |
Re: Dual MC for 39 pedal set
Mr. Texas
You need an adapter. They used to be readily available, but i don't know who sells them now. It allows the use of a new 2 bolt Master to the 39 3 bolt type. As far as a dual master cylinder, the 1967-68 Ford Mustang cylinders work well. Jim |
01-31-2012, 01:28 AM | #3 |
Chassis Engineering has them.Don't have their info.I think they are in Iowa.Try Google for their contact info.WWW,chassisengineering.com Ph 319-643-2645.
01-31-2012, 09:27 PM | #4 |
Try ECI (Enginered Components) in Connecticut. They not only have the adapter, but they can advise on brakes. The make all kinds of brake kits so they should know what master to use.
02-01-2012, 09:14 AM | #5 |
"I would agree with the guys that are telling you to upgrade your mechanical system with floaters/equalizers, woven brake shoe linings, fine tune adjustments, etc., first before thinking about converting to hydraulics. If/when you decide to go hydraulic, give Richard Lacy (Early V8 Garage) a call and discuss your best options for converting to hydraulics. He offers a complete well designed system that requires no drilling or other modifications to install. The master cylinder mounts to the frame using a special bracket and your stock brake pedal assembly works the master cylinder. He also offers all preformed lines and fittings for the complete assembly. He is a member here so you can contact him by PM or Email as well." Early V8 Garage 1217 Azusa Canyon Road West Covina, CA 91790* Phone: (626)338-2282 Fax: * (626)337-1175 Specializing in 1932-1938 Ford Hydraulic Brake Conversion Kits We manufacture our exclusive no-modification kits to install early Ford hydraulic brakes on your 1932-1938 vehicle. We also stock all parts necessary to do the job right. No cutting/drilling/welding is required. Our kits use only existing holes in your original frame, and utilize your original pedals. Kits include linkage to connect your original handbrake handle to the rear cable used by Ford on 1939-1948 hydraulic systems. Our kits can be uninstalled without leaving any trace, should you later wish to return your Ford to original.* Other Ford Parts:* We also specialize in New Old Stock and select used original parts for 1932-1953 Ford passenger and commercial vehicles. FAX or E-Mail your "wanted" list. We maintain a search file of your needs and will contact you automatically when the parts become available! At Early V8 Garage, we provide the personal service that you need to solve your parts problems and increase the enjoyment of your Ford. Our exclusive products include complete do-it-yourself instructions and our pledge to provide answers when you need them! Hours: Live Person: Monday - Saturday 9AM to 5PM FAX/E-Mail: 24 Hours / 7 Days __________________ |
