01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
SOHC in a Bird
The coolest car I ever saw was a '57 Bird SOHC 427 drag car. Disregarding cost for a minute, could I put a SOHC + C6 in a small Bird street machine? Could I find the parts to make it driveable? <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: SOHC in a Bird
I'm not authority on this, but remember back in the early 70's being in a fellow's shop and seeing a SOHC sitting in the corner. It had been in the owner's '55 Crown Victoria and taken out because the owner could not make it run well at lower RPMs to make it streetable. Technology has come a long way since then. Now if you want to throw enough money at it just about anything is possible. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
Re: SOHC in a Bird
Yes it will fit you will have to make motor mounts, and if it is a crate engine you will still have to take it apart and go throught and retime the chain and o other modes, there is a guy with Ford Motor sport who is an expert on this subject SOHC's his name escapes me at the moment good luck$$$$$$$$$$ <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
Re: SOHC in a Bird
The gentleman you're thinking of is John Vermeersch. He has (or at least, HAD) a '61 Starliner that was 'Cammer powered. VERY cool. On the subject of that SOHC early 'Bird, though, you're in for a lot of work and a lot of money - and as for "driveable", that's a relative term if ever I heard one. I will say, however, that the SOHC mill was NEVER intended for a street environment. Indeed, Ford only had to build 500 of the things to homologate it for NASCAR, but declined to do so. I'd say, offhand, that the answer to finding parts to make it 'drivable' would be NO, or at the very least, you'd be looking at some obscene amounts of cash. A modern 429 or 460 could make just as much power (especially the stroker models) with much less expense. A mild 460 could easily crank out nearly 500 horsepower with the right parts and still be very drivable. 500 hp isn't quite SOHC territory, but in a small early 'Bird, it'd be hard to keep up with. Of course, if you're interested only in 'shock value,' the 'Cammer is second to none. <table><tr><td><font face="arial"> |
