01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
Flange to Flange Measurement?
When measuring a rear end out of a car is the flange to flange distance the distance from the axle flange to the axle flange or from the housing flange to the housing flange.Also, wouldn't it be better to give the measurement from wheel mounting surface to wheel mounting surface so as to make it easier for comparison with the original rear. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: Flange to Flange Measurement?
19Fordy they are measured both ways, leave an e-mail adress and i will send you a site that has all that info <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
ford1: Thanx you. [email protected] I'm looking for a Ford 9 in. rear with 61 1/4 " distance from wheel mounting surface to wheel mounting surface. Want to put it in a 51 merc. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
19fordy i tried to send you an e-mail it came back i guess your not a real person lol any way the 9 inch your looking for is out of a 1957 to 1972 f100 p/u 61 1/4 from axle flange to axle flange thats whwere the rim bolts to the axle might be a little low geard but any nine inch pumpkim will fit just watch axle splines 28 or 31 , 31 are stronger, but all you have to do is change axle gears ti get the 31 hope this helps <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #5 |
Guest
Posts: n/a
Thanks ford 1. Plez try and send email again. My email address is [email protected] <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #6 |
Guest
Posts: n/a
http://hiqties.hypermart.net/9inch.html#top That site will tell you everything you need to know on the subject. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #7 |
Guest
Posts: n/a
19Fordy, did you get my e-mails? <table><tr><td><font face="arial"> |
