Old 09-03-2013, 07:58 PM   #1
banjoQ
banjoQ's Avatar
Default 8BA sparkplug verification
I spent some time and went through a forum search. Could not find any info specific to the 8BA. I have a 50' 8BA that has Autolite AL-7s' installed in it. These have been it the motor since the fifties. Currently these are burning a bit black, but they were like that from the day I dragged it out of the shed. Getting caught up on things to do to the truck and now it's time to treat the ol' boy to fresh plugs. Would not be surprised if these are not the correct plug. Autolite no longer uses the AL-7 descriptor. Will Autolite 216s' or Champion D21s' do the job for the 8BA? This seems to be the choice for earlier flatheads.
banjoQ is offline   Reply With Quote
Old 09-03-2013, 08:21 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 8BA sparkplug verification
This will help if your engine is completely stock. However, you will have to cross reference the Champion H 10 spark plug. You will get plenty of answers that vary. Keep in mind all the engines may not be as stock as yours and may have aluminum heads which may require a longer 'reach" sparkplug, etc.
http://www.vanpeltsales.com/FH_web/f...53_239-255.htm
NGK BL 6 is a good start according to this.
http://www.sparkplugcrossreference.c...0-h10-h10.html
Plus, Here's a site you should "save".
http://www.btc-bci.com/~billben/flathead.htm
Old 09-03-2013, 08:22 PM   #3
oldford2
oldford2's Avatar
Oh Boy,
This is like asking if you like blondes, brunettes, or redheads. I like Champion H-12's @ .030 gap
John
oldford2 is offline   Reply With Quote
Old 09-03-2013, 10:02 PM   #4
flatjack9
flatjack9's Avatar
Ngk b6l.
Old 09-03-2013, 10:26 PM   #5
Ross F-1
Ross F-1's Avatar
Just put in a set of Autolite 216's. They work great.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 09-04-2013, 06:13 AM   #6
Vic Piano
Vic Piano's Avatar
Originally Posted by oldford2 View Post
Oh Boy,
John
John,
I like blondes, brunettes & redheads but I wouldn't put Champion spark plugs in a lawnmower... Autolite 216's and Autolite 437's (for aluminum after-market heads) are what I run.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-04-2013, 11:00 AM   #7
banjoQ
banjoQ's Avatar
Thanks guys, for the information. Really found the link "Fordy" gave interesting. Addresses many of the most often asked questions. That's a keeper. The Champion H-10s' and H-12s' are hotter plugs, correct? Is there an advantage to this. My 8BA is in a truck and gets driven frequently. Short hops of ten to twenty mi. are about right for where I live. Maybe a hotter plug is what I need, weather it is a Autolite, Champion, or NGK. Then again, maybe Autolite 216s' are all I need. Beginning to think sparkplugs are like banjo strings. Every picker has his favorites and reasons for it. Nickel or bronze wound, medium or heavy gauge.I know I can't be talked off my brand. Thanks again-Q
Old 09-04-2013, 11:20 AM   #8
19Fordy
19Fordy's Avatar
The good thing about NGK is that that have "rolled threads." The general feeling bandied about these days is that Champions are not the same high quality they were "back in the day." Be sure and put a "dab" of anti-seize compound on spark plug threads and never install or remove them when engine is HOT. Also, don't over tighten and use a spark plug socket.
More info:
http://fordbarn.com/forum/showthread...rk+plug+torque
Old 09-04-2013, 11:30 AM   #9
Vic Piano
Vic Piano's Avatar
Spark plugs are cheap enough for you to perform some test of your own. Install a set and use the truck in your normal driving for say two months (or sooner) pull the plugs and see how they look. Install another set of a different brand and do the same thing... When finished, you'll be able to compare the plugs to see how they held up. You should also monitor the gas consumption variance (if any) between the different plugs. Wow... now I'm sounding too technical for my own good... I usually just fly by the seat of my pants when it comes to Flatheads... By the way, I’m a big Lester Flatt & Earl Scruggs fan…
Old 09-04-2013, 11:44 AM   #10
JT FORD
JT FORD's Avatar
AL 216 work the best for my 8BA's
JT FORD is offline   Reply With Quote
Old 09-04-2013, 12:21 PM   #11
Ross F-1
Ross F-1's Avatar
Originally Posted by 19Fordy View Post
[COLOR="DeepSkyBlue"]The good thing about NGK is that that have "rolled threads." The general feeling bandied about these days is that Champions are not the same high quality they were "back in the day." ..
I don't know of any spark plugs (or bolts, screws, etc) that don't have rolled threads. Champion, Bosch, Autolite, all claim rolled threads on their websites. The real bottom line is rolled threads are cheaper! A machine can roll probably 30 or 40 a minute.
See interesting "How its made" video, at 2:50 they show the rolling process.
http://youtu.be/86wqjQbOw0w
Old 09-04-2013, 01:05 PM   #12
Russ/40
Russ/40's Avatar
I've run different Champions, and Autolites as well as the NGKb6l. The NGKs win hands down for me. Never had a bad one in many thousands of touring miles.
Old 09-11-2013, 10:01 PM   #13
banjoQ
banjoQ's Avatar
Just an update for those that weighed in on my question. As stated in an earlier post, my 8BA had Autolite AL-7s' in it. Probably from the fifties. Armed with the info given by you all, I was able to find a set of Champion H-12s'. Gapped and installed them. I know these were not the popular favorite but the improvement was huge! The Autolites in the motor were in worse shape than I remembered. And the gaps were all over the map! At any rate, these will certainly do for now and I have some time to track down a set of AL 216s' for later. Thanks again for the advice.
Old 04-02-2014, 11:05 PM   #14
Topsterguy
Topsterguy's Avatar
What do you gap these at?
Topsterguy is offline   Reply With Quote
Old 04-03-2014, 01:58 AM   #15
49r
Champion H-10, gap 25.
49r is offline   Reply With Quote
Old 04-03-2014, 08:58 AM   #16
Ross F-1
Ross F-1's Avatar
With stock ignition, .025".
Old 04-03-2014, 10:20 AM   #17
51504bat
51504bat's Avatar
Originally Posted by Vic Piano View Post
John,
The last set of Champion H-10 plugs I bought for my 8ba were individually packaged as small engine plugs. So Champion H-10 plugs ARE lawnmower plugs.
Old 04-03-2014, 10:27 AM   #18
Topsterguy
Topsterguy's Avatar
LOL, thanks for the info guys, but I have to agree....... Champion plugs are for lawnmowers so I think I'd stick with the Autolite 216's!
