11-22-2018, 01:37 PM | #1 |
Rear Axle Shaft Repair?
I'm working on a '40 pickup rear end. The left side axle has a worn out keyway and is actually broke out at the end. The threads, bearing/seal surfaces and side gear are in good shape.
Has anyone had any luck welding up the taper and having it re-cut? Does anyone know where I might find a replacement axle shaft? Thanks, Paul |
11-22-2018, 02:08 PM | #2 | |
Re: Rear Axle Shaft Repair?
To repair, the axle will need to be (re) heat treated properly. This is a process that is very costly to do correctly on a "one off" piece.
11-22-2018, 02:28 PM | #3 | |
Put your general location in your profile!!! A guy in your same town might have one but not want to mess around with taking pictures, giving descriptions and shipping (that sounds like me but I don't have an axle). Charlie Stephens Last edited by Charlie Stephens; 11-22-2018 at 02:34 PM. |
11-22-2018, 02:51 PM | #4 | |
Thanks Charlie |
11-22-2018, 02:49 PM | #5 |
I agree that a good used or better yet a NOS axle shaft is the best option however I have been searching and I'm not able to find one.
11-22-2018, 02:56 PM | #6 |
11-22-2018, 03:18 PM | #7 |
11-22-2018, 04:54 PM | #8 |
Paul, I've sent you a private message...
11-22-2018, 02:50 PM | #9 |
If you decide to have your damaged axle repaired, I would suggest having that axle magnafluxed to check for cracks on the taped end.
11-22-2018, 04:22 PM | #10 |
I know that 6 months ago, Bob Selzam had one only nos 81A 4235, but it is slightly rusty....
