07-04-2021, 03:12 PM | #1 |
Original 1942 Lincoln Continental Coupe with title
City:
Temecula
State:
Ca
Price:
$8650
Car has been in storage since it was last registered in 1968.The interior is in good condition including the headliner,which has a small hole in it.Vacuum canisters under both front fender for operating antenna.Trim is oxidized but will clean up nicely and none is
missing.Has both original fender skirts..Stainless exterior body trim is also in good condition and is all there.Original rear license plate light is missing.All glass is in place with only 2 vent windows that have cracks.Both doors open by pressing a button from inside and out.Have original key for ignition.Dash components are all original including the radio.Also has a spot light.4 brand new thin white wall tires.Original engine was replaced with a 1949 Olds Rocket 88 "303" back in the day.Newly rebuilt carb,water pump,starter all of which are installed.Engine has been adapted to the original Lincoln 3 speed overdrive transmission with all components still in place.Engine does crank over but needs to be rebuilt..A original V12 and trans are available if needed.Tail lights and horn work but everything needs to have the ground reestablished from having sat for so long.Vin numbers are visible in both factory locations on front frame rail and rear side rail by gas tank neck H129842..Title has been applied for and should be arriving soon....Extra parts include a rear bumper,extra hubcaps.. More pix are available..Local delivery is available..760-717-1334 Last edited by fordtrk56; 07-19-2021 at 04:03 PM. Reason: pix |
07-14-2021, 10:08 AM | #2 |
Re: Original 1942 Lincoln Continental Coupe
