Old 12-20-2015, 04:40 PM   #141
mrfliboy
mrfliboy's Avatar
Default Re: 1941 Ford Pickup frame-off restore for the next generation
Who can believe, 5 days before Christmas and its 50 out.
Had to try out the new shoes Big Grin Had a buddy take a test drive also and he was impressed, makes it all worthwhile.
Drove it a total of 6 times, each one more pleasurable than the first LOL.
https://www.youtube.com/watch?v=1NvogOyVdZo
mrfliboy is offline   Reply With Quote
Old 12-20-2015, 04:49 PM   #142
mrfliboy
mrfliboy's Avatar
Still Smiling
Old 12-20-2015, 05:22 PM   #143
mrfliboy
mrfliboy's Avatar
Originally Posted by 41panelmark View Post
Some great metal work going on for sure.
Thank you, appreciate it.
Old 12-20-2015, 06:17 PM   #144
Vanspeed
Vanspeed's Avatar
Good for you!! Happy to see it up and running.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 12-27-2015, 04:33 PM   #145
OldFordFan
Congratulations mrfliboy. It sounds good running.
OldFordFan is offline   Reply With Quote
Old 12-27-2015, 06:25 PM   #146
mrfliboy
mrfliboy's Avatar
Thanks Guys, still have a big old grin.
Old 12-31-2015, 03:03 PM   #147
mrfliboy
mrfliboy's Avatar
Christmas present form my wonderful wife. She actually went and checked my tire sizes to get the perfect fitting set.
Old 01-04-2016, 10:05 AM   #148
mrfliboy
mrfliboy's Avatar
Time for final tear down and onto paint. Oh Boy!!!
Luckily my passenger door was original and still completely intact. My disassembly was as the pictures go , One way to do it I guess.
Was able to remove the glass and not destroy anything. But also found some rot along the bottom edge that will need to be addressed.
Also I found remnants of (I presume) original glass down inside door.
Got the complete wiring harness out in 1 piece. Wasn't as bad as I thought actually. Unfortunately my gauge panel will need some interior work, chunks of paint floating around and now missing numbers off odometer. Hard to believe this was still operational.
Will be removing cab tonight, frame going outside, building my spray booth this week hopefully.
Old 01-08-2016, 03:41 PM   #149
mrfliboy
mrfliboy's Avatar
Got the Booth almost completed, (done) hoping to lay some paint down this weekend. Kinda hard to show the size, basically 12' x 8'.
Picked up my 2K Epoxy, gun, sandpaper and ready to paint.
Did some rust treating with KBS RustBlast, like it much better than Ospho. Seemed to work a lot faster.
Underside of running board was wire brushed, degreased, Rustblast treated, scrubbed during this time with scotchbrite pad for 1 hour. Rustblast wiped off, than rinsed with water. Compressed air dried. 2K epoxy sealer applied with gravity feed gun.
High build primer applied 3 coats
Got my work cut out for me for the next few winter months. LOL
Old 01-09-2016, 03:31 PM   #150
Sixseven
Sixseven's Avatar
Did/do you find rust along the interior top of the windshield? Curious about that because I've seen several like that but it seems like an illogical place for rust.
Sixseven is offline   Reply With Quote
Old 01-15-2016, 12:17 PM   #151
mrfliboy
mrfliboy's Avatar
None on mine, but lower is in need of serious treatment. No rust thru at least.
Old 01-30-2016, 10:39 PM   #152
mrfliboy
mrfliboy's Avatar
Trying my luck at bondo.
3 coats high build primer, blocked with 80.
First attempt at filler, too hot and got hard quick, ended up scraping it all off.
Second attempt much more useable, small area but looks more like it should.
Blocked with 80 and than marked all my areas needing filler.
Laid some more filler, blocked it with 80 on a air board sander.
150 fpm air movement across fender, perfect.
2 coats high build primer, drying now for the night.
A few flaws but hey its a 75 year old truck.
Old 01-31-2016, 11:05 AM   #153
Curt in AZ
Curt in AZ's Avatar
Wow, what an amazing illustrated chronology of the build. How are you moving air through the booth? Thanks.
Curt in AZ is offline   Reply With Quote
Old 01-31-2016, 05:23 PM   #154
mrfliboy
mrfliboy's Avatar
Thanks
The exhaust is a fan I had picked up 25yrs ago. I actually have had this design, idea (my booth) since than. When my VW was ready for paint, I decided it was better for a expert to finish it. The fan is located up in the peak of my garage and connected via a cloth flexible duct.
20 years lster , I decided to do this truck all myself.
I have a approx 24 x 30 filtered intake. Which gives me a nice airflow of 150fpm across the spray area.
Old 01-31-2016, 06:41 PM   #155
Binx
Looks like you're not going to leave much work for the "next generation"
Lonnie
Binx is offline   Reply With Quote
Old 01-31-2016, 07:51 PM   #156
mrfliboy
mrfliboy's Avatar
Lonnie
LOL
The whole drive train and engine are staying original, that should give them something to clean up and paint.
My wife wants nice paint and interior and that's what she'll get.
Old 02-09-2016, 03:10 PM   #157
mrfliboy
mrfliboy's Avatar
Other fender done, little filler and 3 coats high build primer.
Jumping around a bit, decided to tackle the underside of the cab.
Normal routine on the underside. Wirebrushed, than AquaKleaned, then RustBlast (ospho), degreased and finally tacked and sprayed with RustSeal
Opened up side of booth to fit the cab in there.
2 coats RustSeal and now have all my undersides done (bed excluded)
Lastly sprayed a test panel of a possible color for the truck. Gray with a blue tint. Still totally undecided on color. Might go with a burgundy or maroon even. Wife is still debating. LOL
Old 02-12-2016, 07:15 PM   #158
mrfliboy
mrfliboy's Avatar
Purist's might want to look away. This is the heater that was in the truck.
CHEVROLET SUPER DELUXE.
Curious was there a Ford Deluxe
Old 02-15-2016, 09:58 AM   #159
stovebolt
stovebolt's Avatar
What are the two tabs at the very front of the frame used for? Did the passenger car frame have them also? You're doing very nice work on a very nice truck.
stovebolt is offline   Reply With Quote
Old 02-15-2016, 01:44 PM   #160
mrfliboy
mrfliboy's Avatar
Thanks
The truck frame horns were different than the passenger car frame. I swapped over to the original truck frame horns. Not sure what the outer holes are for, the other set is for the radiator.
