02-19-2021, 11:55 PM | #1 |
Looking to identify parts and value
Looking to identify year(s) and value of door felt trim metal. 14 3/4” inch tall. Thinking Standard model years?
Looking to identify and value of Deck Lid hinges, they are shorter than 39-40 Fords. Thank You Joe Last edited by Bazooka Joe; 02-20-2021 at 09:33 AM. |
02-20-2021, 09:49 AM | #2 | |
Re: Looking to identify parts and value
The lid supports are pretty much worthless, maybe $10 or so IF they will support the lid.
02-20-2021, 10:37 AM | #3 |
The metal trim is 1/8” wide. I’m just saying for Standard cars? as the front bottom part is not as wide as in my 39 Deluxe. The measurements are the same as I have in my car, a Deluxe Coupe. ( 14 3/4” tall X 31” long. ) I’m not familiar with the height and length of a driver side door felt upholstery trim on a “ sedan “ reason for asking.
I think the deck lid hinges has value, ( repop springs can be purchased if hinges don’t hold decklid up ) especially if they don’t make this type in repop. I’m not sure how a 37-38 Ford Coupe deck lid hinge looks like, if it’s manual lock, if so then not sure where these go or even what manufacturer of auto. If the 37-38 Ford Coupe uses spring hinge types ( like the 39-40 and later ) thinking maybe they go on those year cars? As the decklid is smaller than the 39-40 so thinking the hinges will be smaller, which they are compared to the 39-40. This one looks to have the original factory color of a very dark blue. I’ve owned many parts for 51 years, ( as it came with my 39 which I purchased it in 1970 and still own ) and needing to prioritize the parts that I’m not familiar with for future sale. It’s not like I’m a young kid anymore. Thank You Last edited by Bazooka Joe; 02-20-2021 at 10:53 AM. |
02-20-2021, 10:40 AM | #4 |
They 37 Ford coupe deck lid had a manual mechanism to lock it upright (not something with springs).
02-20-2021, 11:10 AM | #5 | |
02-20-2021, 12:24 PM | #6 |
02-20-2021, 12:28 PM | #7 |
Thankx, did see some ( what looked like original 37 Coupes ) with one hinge ( drivers side only ) with springs on it but the angle piece that mounted onto the decklid with the two screws where, had a different configuration, so guessing that was changed from original manual locking clips?
02-20-2021, 12:43 PM | #8 |
Nice looking 39 coupe by the way,Bazooka !
02-20-2021, 12:53 PM | #9 |
It's possible the trim fits '39 as well but I don't think so. I simply can't recall for certain. I've attached a photo of '39 std. trim. They don't look like yours.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 02-20-2021 at 01:00 PM. |
02-20-2021, 02:41 PM | #10 | |
A similar but longer support, p/n 78-7068970-B, was used on sedans. You might checkout the Automotive Trimming and Supplies catalog, page 13, for more details. I don't have a copy of that publication yet. Last edited by Zeke3; 02-20-2021 at 02:48 PM. Reason: added info. |
02-20-2021, 02:54 PM | #11 | |
38 deluxe >>> 39 standard 39 deluxe >>> 40 standard If they fit '40 standard then they have a better chance of fitting 39 deluxe than a 39 standard??
Sometimes, ingenuity gets in the way of sense and sanity. |
02-20-2021, 03:24 PM | #12 |
Just found these in my shop. They came off '38 deluxe fordor. Pic is of front passenger door(right). 14 3/4" tall x 31" wide. Appears to be the same in your photo.
02-20-2021, 03:28 PM | #13 |
02-20-2021, 03:35 PM | #14 | |
02-20-2021, 03:51 PM | #15 |
They do not look like the 39 std. trim in my photos. Look at the bottom corners...
02-20-2021, 04:13 PM | #16 |
Yes, Thankx, for your help, yes certainly a tad different.
02-20-2021, 04:22 PM | #17 |
Thankx for the kind words, mostly original looking, Lebanon Bonney mohair interior, Wood Grain dash by Elmo’s Grainmobile, decades ago. 46 Canadian block, with hop up parts, converted to 12 volt pointless ignition many years ago. Bought ignition system from Patrick’s years ago. Modern 15” tires, with nostalgia rims, still has vacumn wipers. Dropped front axle. This September will be 51 years of ownership, a lot of blood, sweat and tears to get it to look like it is now....once again Thankx for the kind words..
02-20-2021, 06:52 PM | #18 |
Deluxe 39 and 40 see attached.
02-20-2021, 06:58 PM | #19 |
See attached.
02-20-2021, 07:05 PM | #20 |
See attached.
