03-05-2021, 08:02 AM | #1 |
32 Sedan Project Pt. 30. Let's shove the Ol' 59 Flatty in! +41PU Charging!
I fit the trans and water pumps to the Ol'59 Flatty. This is the final piece in the jigsaw allowing me to get the motor in. So that's what I did. I put the engine and box in, and the job went well. I share a top tip to help people doing the same job. I also share some footage from when I was sorting the charging out on the 41 pickup. That also went well, It is now charging nicely, using the original regulator. A bit of cleaning and tweaking sorted that out. So a big milestone for the 32 and the Ol'59. Chassis is rolling, motor is in. I can treat the 32 frame as an engine running stand now and work towards getting the motor running. Hope you find something interesting or at least entertaining. Look after yourselves and I'll catch you next time. Mart. https://youtu.be/zd6reUxhO3w |
