Old 07-07-2016, 04:20 PM   #1
Macdozer
Default Starter button
On my 1936 ford with 59 ab engine I installed a solenoid with the push button on the top of it. When I use this button things work fine, but when inside the car and I use the button on the dash the starter stays engaged and the engine will keep turning over until I disconnect the battery. Or it just clicks and nothing happens.
I checked the button and it works fine.
Any ideas on what could be the issue?
Macdozer is offline   Reply With Quote
Old 07-07-2016, 04:32 PM   #2
JSeery
JSeery's Avatar
Default Re: Starter button
The button should be just a ground to the solenoid. Did you try just grounding the solenoid at the terminal? Use a short piece of wire and ground the small center terminal to ground and see what happens. If the problem still exist you have a bad solenoid or an incorrect solenoid you your car. If it works ok at the solenoid then the push button is defective in some way.
Old 07-07-2016, 05:18 PM   #3
Lawson Cox
Lawson Cox's Avatar
THE PUSH BUTTON GOES ON THE BOTTOM OF THE SOLENOID, NOT THE TOP.
Didn't mean to yell at you. When you push the button, it raises a copper plate that completes the circuit, release it and the copper plate or bar falls back down and breaks the circuit. (Or at least that is the way all of them I have ever seen work.)
Old 07-07-2016, 05:25 PM   #4
Reisterstown Ray
I always thought that the push button on the bottom of the solenoid was a great idea. Being in the engine compartment was real handy. RR
Reisterstown Ray is offline   Reply With Quote
Old 07-07-2016, 05:56 PM   #5
adileo
adileo's Avatar
Did you just put solinoid in? That happened to me and or wound up I over tightened the nuts on the solinoid
adileo is offline   Reply With Quote
Old 07-07-2016, 06:09 PM   #6
russcc
As already noted. On the bottom is on target. Greatest invention since sliced bread to turn over the engine with you head under the hood.
Old 07-10-2016, 12:30 PM   #7
Macdozer
Here is what I have , bought it already assembled
I think top and bottom got mixed up.
Does anyone know where to buy a good quality one, this one seems pretty cheap.
Sent from my iPad using Tapatalk
Old 07-10-2016, 01:51 PM   #8
JSeery
JSeery's Avatar
Use a meter to check the continuity from the center post to the two side post. One should have continuity and one should not. The side with continuity is the battery side and the one without is the starter side. If no continuity it is the wrong type of relay.
Old 07-10-2016, 02:03 PM   #9
sunshine
sunshine's Avatar
I bet when you turn the starter solinoid over and mount it your starter button won't stick any more. Sunshine
sunshine is offline   Reply With Quote
Old 07-10-2016, 02:03 PM   #10
Bob C
There are nine different solenoid circuits, I think #2 is the one you want.
Bob
Old 07-10-2016, 02:54 PM   #11
Ken/Alabama
Ken/Alabama's Avatar
Make sure the cables are connected to the correct post. One of them should be marked Batt.
Old 07-10-2016, 03:04 PM   #12
JSeery
JSeery's Avatar
I agree, that's why I suggested checking it with a meter to be sure
Old 07-10-2016, 03:05 PM   #13
Kube
Kube's Avatar
It does not work with gravity. That "connection plate" within is under spring pressure.
My guess is the solenoid is either incorrect for this application or wired incorrectly as jseery has eluded to.
Old 07-10-2016, 03:06 PM   #14
Kube
Kube's Avatar
Yeah, a great invention. More commonly referred to as "the dead man's switch".
Old 07-10-2016, 03:12 PM   #15
jack orchard
I agree. Wired backwards.
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 07-10-2016, 08:12 PM   #16
slowforty
slowforty's Avatar
I bought one of those from E bay. It worked for a while and then the starter would engage by itself. Very disconcerting.A sharp rap with a wrench would solve the problem. Later I bought a new Solenoid from a better quality supplier. I took the old solenoid apart and it was typical Chinese Quality. But now i have about 15 feet of copper wire to use.
slowforty is offline   Reply With Quote
