02-06-2019, 08:25 PM | #1 |
Boot for shifter and Brake 1952 F-6
Has anyone found a boot for the shifter and parking brake on a truck? I'm looking to close in the gaping hole in the floor between the two. I also need one for the PTO lever too. Are these available anywhere? Google and the search function above aren't hitting anything....
02-07-2019, 10:47 AM | #2 |
Re: Boot for shifter and Brake 1952 F-6
I think it's the same cab as my F3. NPD and other's have the shifter boots.
02-07-2019, 11:16 AM | #3 |
They generally just had cut outs in the floor mat. I don't recall any boots but there may have been. The trucks were older when I started driving them. There were variations in PTO controls too. Some were cable operated and some were lever operated. It depends on the manufacture of the dump box for those.
02-07-2019, 11:29 AM | #4 |
I dig coal, which provides motivation for EVs. |
02-07-2019, 12:39 PM | #5 |
I think rotorwrench is correct. I looked in the parts book and it only shows trans
and hand brake boots for the cab-over not the conventional. Also the picture they showed of the conventional had a floor mat but no boots. |
02-07-2019, 02:31 PM | #6 |
02-07-2019, 08:13 PM | #7 | |
02-07-2019, 02:39 PM | #8 |
The one that 1952 Henry posted is what's in my F3. It also has the big rubber/foam doughnut under the cover plate.
My hand brake lever didn't have any kind of boot when I got the truck and I don't have a PTO. I'm sure a generic boot would work if desired. |
02-07-2019, 11:43 PM | #9 |
If you aren't worried about a Dearborn-level resto, take a look at this solution from a guy on FTE:
'52 F-1, EAB flathead |
02-08-2019, 07:40 PM | #10 |
Yes, that is one I was looking at for a Jeep. I'm going to put the brake onto the tranny and measure the distance between levers this weekend. I think that one will work. This is definitely not a Dearborn-level resto. Its just a fun truck to drive and use. After I retire I might consider a resto, but first I have a '51 F1 that's getting the hot rod treatment. Power steering, Disc brakes on a Mustang 2 front end and a warmed up 351 Cleveland wedged between the frame rails.
02-08-2019, 05:14 AM | #11 |
A boot from any 4x4 lever is what I used dime a dozen in the junk yard..
