02-23-2014, 08:50 PM | #1 |
Does anyone know what carb this is?
Does anyone know what carb this is? I want to get it rebuilt.
02-23-2014, 08:53 PM | #2 |
Re: Does anyone know what carb this is?
Looks like a Tillotson x to me.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
02-23-2014, 09:39 PM | #3 |
Yup. Tilly X. Rebuild parts are fully available.
Joe K
Shudda kept the horse. |
02-23-2014, 09:40 PM | #4 |
Yep, Tilly X. good carb. Do NOT overtighten the screws and bolts else it will warp. Most ppl tighten way too much.
If you are gonna do it yourself I recently posted a method to get the main jet out, which can be quite a challenge. search under my username https://www.fordbarn.com/forum/showth...ghlight=method
'31 180A Last edited by tbirdtbird; 02-24-2014 at 09:59 AM. |
02-23-2014, 09:40 PM | #5 |
Yes, it's a Tillotson Model X, and mounted with bolts with nuts because the threads in the upper flange have been stripped. I've got one like that.
02-23-2014, 10:38 PM | #6 |
02-23-2014, 10:59 PM | #7 |
In Moller's book he says this is an insurmountable issue. I sure don't have a workaround. Check ebay they come up all the time for 30-60 bucks, use yours for parts
'31 180A |
02-24-2014, 05:15 AM | #8 |
Two major problems with Tillotsons - 1) they warp and 2) the threads get stripped. Some warpage can be overcome by very careful fettling. Overcome stripped mouting threads at the manifold with nuts and bolts ( as your's already has), stripped threads at the drain plug can sometims be fixed with a helicoil insert but stripped threads at the gas inlet generally make it beyond encomical repair. ( you can bodge a get-you-home measure with PFTE tape or JB weld)
02-24-2014, 08:51 AM | #9 |
Thread repair in the mounting lugs is surprisingly easy. See
http://www.cedarcreekas.org/TechTopics/SalvagedCarb.pdf |
02-24-2014, 11:33 AM | #10 |
IMHO with Tillotsons if the mounting threads are stripped it's better to use a nut and bolt rather drill even more metal away for a Helicoil insert. Zeniths are much tougher all round and I agree that Helicoiling Zenith mountings is a good option.
02-24-2014, 11:38 AM | #11 |
well gentlemen we seem like we all found something we all agree on . it is a tilly x !!!!!!
