07-08-2010, 10:40 PM | #21 | |
Re: Oil spewing out of oil filler pipe
The Model B engines did not have counterweights at first. The CWs were added later (first ones were wider and later ones were narrower) and then the fourth design, the large B tube breather with a completely different baffle design was added. That said, the SB pages 358 and 454 were written to address the vapor problem for cranks WITHOUT counterweights. Adding CWs to an A crank most likely throws more oil up and out of the breather tube. Last edited by Benson; 10-15-2010 at 08:37 AM. |
07-09-2010, 12:53 AM | #22 |
Don look at page 454.
Old spewing must have been a big problem back then ...perhaps as the engines wore out?... whatever the case page 454 shows Ford's final improvement with the tabs facing down in the direction Brent indicates. Yes I'm another guy running off to check my pipe No doubt a ton of testing went into the design change way back then so this final pipe would the one of choice for a non-purist. (or the B pipe) Now-a-days we have carefully trained service managers who dumb down the car owners with phrases such as "gee we haven't heard any other complaints on that" and my favorite "we can certainly sympathize with your situation" 2nd stage would be installing several identical pipes at the customer's or warranty company's expense. 3rd stage, given a wide enough range of troubles in a single model they can always re-name the car a sell it for a few more years. Bankrupt? Hang on while we bail you out. |
07-09-2010, 01:59 AM | #23 |
Going to check mine as soon as i get a chance.
07-09-2010, 08:05 AM | #24 |
All this talk about checking pipes? If you aren't spewing oil why the worrying? If you were you'd know. JMO
Paul in CT |
07-09-2010, 10:30 AM | #25 |
Just a quick thought for future reference - some of the new reproduction oil dip sticks do not have accurate readings for the oil levels - an original is always best.
