02-07-2015, 08:07 PM | #1 |
Need help with a 1940 Ford Panel
I'm the new owner of a 40 Ford Panel and just pulled it into my shop and noticed something strange about the hood / front fenders.
The fenders and hood were inside the panel when I bought it and as I pulled it into my shop I started to mock up the hood and fenders and noticed the the line where the hood meets the fenders does not look right. It looks like there is a gap between the hood / fenders and body. Does the photo below look correct ? Thanks for any help Mike |
02-07-2015, 08:15 PM | #2 |
Re: Need help with a 1940 Ford Panel
I believe you have a car hood. Panels and trucks did not have side stainless.
02-08-2015, 12:06 AM | #3 |
Definitely not truck hood, possible the fenders are not either but need more photos. This is what the front should look like.
02-08-2015, 01:50 AM | #4 |
Any chance it's a 3/4 ton panel which would have entirely different front sheet metal than the sedan delivery? The wheelbase looks kinda long to be a sedan delivery.
02-08-2015, 10:08 AM | #5 |
That "flathead" looks a little suspicious, also! DD
02-09-2015, 03:29 PM | #6 |
I just bought the Panel from a shop about 20 miles down the road. It is sitting on what looks like a 70 Chevelle Chassis and the geometry looks right. It appears that they only installed the big block 454 in there for mock up of the firewall (It needs a complete rebuild). I will be installing a Ford Drivetrain first and foremost and already have a 4.6 police interceptor with AODe tranny out of a crown vic sitting on the floor in my shop. I appreciate the feedback on the (Car Hood) and the fact that car hoods came with the stainless trim. It looks like the truck hoods had an embossed/raised metal strip down the side. That makes sense and I should be able to make this hood work with a little fabrication. Thanks again Mike |
