06-17-2021, 09:57 PM | #1 |
1936 5 window coupe doors
How to align front door gaps.Doors are sagging at rear
06-18-2021, 09:13 AM | #2 |
Re: 1936 5 window coupe doors
Some background information: wescottsauto.com > tech information > installing body and fenders. Also, http://modelaclub.com/archives/tech-tips/1211. For frame diagram: wescottsauto.com > tech information > 1935-40 frame diagram.
First step is to find and correct the root problem(s). This could include: Door hinge screws loose. Door hinge pins or hinge pin holes worn. Structural deterioration of the cowl or door. Structural deterioration or frame damage. Deterioration or missing body to frame pads. Improper shimming of body to frame. Door hinges needing to be bent to set the door in opening. Not an easy answer. |
06-18-2021, 01:11 PM | #3 |
What shape are the door hinges in??
Paul in CT |
06-18-2021, 08:51 PM | #4 |
They are straight and fit the slots in the body firmly. The halves that are welded to the door are secure. I put new cork and rubber strips down before I set the body back down (I did a frame off resto) I’m thinking more and more that shimming may be what I may have to do to on the cowl end to get the gaps back.
Thanks, Mike in Mich. |
06-18-2021, 11:25 PM | #5 | |
You should have said all this in your first post. |
06-19-2021, 09:08 AM | #6 |
