02-10-2016, 01:06 AM | #21 |
Re: clutch not disengaging
Do you have an inspection cover on top of the trans bell housing ?
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-10-2016, 02:56 AM | #22 |
They used to make pressure plate with 3 adjusting screws with like nut 6 point on end of finger. This was done to get the correct spacing.
Now if you look at a clock face the distance from 1 to 11 travel is more then 12 to 10 o'clock. Those screws take-up space. I think when you remove the pp you will find NO Screws. Maybe FT Wayne has old style PP. Another thing is the 39 pedal has very little movement, and the 39 lever is a one year and is about 3" long. That's my guess. |
02-10-2016, 09:00 AM | #23 |
The reason the 39 pedal has little movement is because the clutch fork lever is short - that means that the actual throw-out bearing moves a lot more as compared to a 32 clutch fork lever (which is almost twice as long). The pedal pressure will be a lot more (given the same length pedal) - but so will the actual throw-out bearing movement (per inch of pedal travel). My guess, something is hanging up with the clutch disc . . . but we will see soon!
02-10-2016, 09:54 AM | #24 |
Here is another way to tell the travel of a lever.
Clock 1-11 ten minutes big hand Clock 1-11 ten minutes little hand Measure 1 A ----11 B big hand now do little hand. Same travel but takes less horz travel. I had a 39 with a 32 lever longer, same problem the stock 39 lever is about 3" |
02-10-2016, 02:48 PM | #25 |
No inspection cover.
I think I have ruled out any possibilities of it being the pedal arms or external linkages or how far they travel by eliminating them and rotating the cross shaft as far as it will go before something inside the clutch assy limits it. Since the clutch disc, throw out bearing... were included in kit from Cornhusker and he says they have many out there with no issues the other likely causes would be: 1)Trans input shaft too long putting pressure on pilot bearing or back of crank. - think I will loosen trans to bellhousing bolts and pull trans back 1/8-1/4" or so and see if that fixes issue 2) pressure plate issue, 3 fingers need to be adjusted out more? I do seem to recall they did have to bolts or nuts on the end.. not missing as was suggested a couple posts up. Any body else have any other possibilities? |
02-10-2016, 03:39 PM | #26 |
02-10-2016, 05:44 PM | #27 |
fftodster>>>Any body else have any other possibilities? >>>
>>>I have a sinking feeling it may be the clutch disc hub up against the pilot bearing.>>> Now how do you suppose that could happen? Jack E/NJ |
02-10-2016, 06:07 PM | #28 |
If the fingers can be adjusted, then it is possible to get the plate disengaged.
Of course it must come apart Problem though, is with no inspection hole or other access; kinda hard to hit the nail on the head when you can't watch the hammer. Still curious as to what changed between first test and drive line install.
Enjoy yer day. Tom Hate can't fix what it started. |
02-10-2016, 08:01 PM | #29 | |
After talking with him he said it would not be the issue with the 9" disc he supplied, that was an issue in the past with some store bought discs... |
02-10-2016, 08:52 PM | #30 |
I think you have a assemble problem.
Clutch disk on backwards, fork on backwards. The screws on pressure plates are "NOT to be touched" The new PPs don't have any and come up about 5/8" inward because of the new way. foreign made. Time to remove it and see what you find. |
02-10-2016, 10:08 PM | #31 |
George/Maine>>>Clutch disk on backwards, fork on backwards>>>
Thinkin' the same thing George when I posed the question. Jack E/NJ |
02-13-2016, 08:22 PM | #32 |
Well what a nightmare!!!
Pilot bearing stuck to input shaft. What a chore to get apart. Had to pull on trans with a strap wench to rear end, and pry, wiggle, lots of cussing... finally got a bit of movement but would still not come apart. Finally got it about 11/2" apart. Then pulled oil pan (not easy in car) then I was finally able to loosen pressure plate bolts and it came apart. Last edited by fftoddster; 02-13-2016 at 08:29 PM. |
02-13-2016, 08:28 PM | #33 |
Clutch disc in the correct way, throw out bearing fork correct....
Guess that's why it worked briefly then stopped working. Worked till pilot bearing seized to input shaft. Why? had soaked it in oil for a couple hours and had added a small amount of grease to input shaft... |
02-13-2016, 08:49 PM | #34 |
Bushing might not've been squarely seated?
Jack E/MJ |
02-13-2016, 08:54 PM | #35 |
Get one like this >
02-13-2016, 08:57 PM | #36 |
Yep, that's what I use too. Still gotta be squarely seated.
Jack E/NJ |
02-13-2016, 09:22 PM | #37 |
Did the bushing come from Cornhusker? That setup requires a special bushing (which you are most likely already aware of). If it is the correct bushing and it was installed square in the crank, then I would be checking the T5 input shaft to make sure it does not have an issue that is hanging it up. There is a lot of debate on which is better, a bushing or a bearing. I lean toward the bearing.
02-13-2016, 09:37 PM | #38 |
When you get it apart show us a photo of it. I couldn't see what you were trying to show. I didn't see a pilot bearing.
02-13-2016, 09:44 PM | #39 |
His finger is pointing at the brass-colored bushing.
Jack E/NJ |
02-13-2016, 10:09 PM | #40 |
It didn't look like it was on the input shaft and really large, maybe it is just my eyesight or the fact I am seeing it in 2 dimension.
