Old 09-06-2015, 03:09 PM   #1
36 ford
36 ford's Avatar
Default Setting the points on a Bubba crab
First experience with a crab and this is one of Jim's. I see allen screws in there and what looks like black adjustment screws which are torqued tightly. My 39 wouldn't start although it wanted to so I pulled the crab and see that one set of points are not opening all the way.
Sure could use some pointers.
Phil
36 ford is offline   Reply With Quote
Old 09-06-2015, 03:34 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Setting the points on a Bubba crab
Phil,
We use stainless allen screws and then use a ball allen driver to set these up. They seem to stay adjusted and the ball tool allows pretty easy adjustment .
If ya cant get it set ship it back to us for a machine set up at no charge.
I really want to know when one of our units have a problem as we take pains in preventing this from ever happening.......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-06-2015, 04:18 PM   #3
Bassman/NZ
Bassman/NZ's Avatar
Originally Posted by BUBBAS IGNITION View Post
Phil,
Don't ya just love the Barn? This reply from Jim just epitomises what the Barn is about!
Bassman/NZ is offline   Reply With Quote
Old 09-06-2015, 04:47 PM   #4
36 ford
36 ford's Avatar
Thank you, Jim! I will send it to you with a note in the box and return postage.
Phil
Old 09-06-2015, 05:41 PM   #5
Capt Kirk
Capt Kirk's Avatar
A rare breed right there...someone willing to stand behind his work even when he doesn't have to. Kudo's from me Jim.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 09-06-2015, 09:53 PM   #6
FireEngineMike
FireEngineMike's Avatar
Don't forget the Ale 8 and moon pies for even faster service.
FireEngineMike is offline   Reply With Quote
Old 09-07-2015, 09:39 PM   #7
Lawson Cox
Lawson Cox's Avatar
R C Cola is the only drink to wash down a Moon Pie. Grin
Old 09-07-2015, 11:37 PM   #8
47COE
47COE's Avatar
Phil,
I've been meaning to tell you about a problem I found with a distributor from my 47 truck that you worked on.
The truck didn't run right but I didn't know why. I did figure that the reworked distributor was probably OK.
Well it finally quit dead. Skipping over a bunch of head scratching I found that the primary contact was intermittent. See the arrow in the picture below. Took it apart and cleaned up both surfaces with emery cloth and that fixed it. Is cleaning both of those surfaces part of your normal procedure? Apparently it wasn't done when my distributor was reworked.
This distributor was in the truck when I got it 40 years ago. And it could have been there many years before that. So it had plenty of opportunity to develop a layer of crud on one or both of those surfaces. I worked on the points once in awhile over the years, but never the sliding primary contact.
Tom
47COE is offline   Reply With Quote
Old 09-07-2015, 11:38 PM   #9
ford38v8
ford38v8's Avatar
Bah, Rednecks. Sierra Nevada Pale.
Alan
Old 09-08-2015, 08:49 AM   #10
BUBBAS IGNITION
Tom
We typically polish the brass contact on a wire wheel and clean the removable contact as well. Each button is checked for tension and any unusual is thrown away . The contact is then sprayed with electrical contact enhancer and then ran on a machine for some time.
I actually test and run each unit and apply the purple ( called spark) nail polish to the screws as a reminder thats it all ok.
BUT ya know things do happen ................
[email protected]
