Old 10-04-2018, 02:53 PM   #41
Y-Blockhead
Y-Blockhead's Avatar
Default Re: checking timing
Originally Posted by old31 View Post
Any advantaged to using the wrench vs the crank?
The advantage is you are on the same side of the radiator as the distributor and can observe the light and/or rotor position. Or you can't turn the crank backwards. Or you have a Tool Box is your way, as I do...
Other than those I can't think of any.
Old 03-26-2019, 09:23 PM   #42
SkimmerBob
SkimmerBob's Avatar
Thanks everyone I used this thread to get mine back in time.
Thanks Tom Wesenberg for the picture that helped a lot.
Thanks Y-Blockhead for the suggestion on the bent wrench. I will go get me a wrench to bend this weekend at the local "Dirt Mall" (Outdoor Flea Market).
SkimmerBob is offline   Reply With Quote
Old 03-26-2019, 10:10 PM   #43
Anteek29
Anteek29's Avatar
Had a good laugh from what Y-Blockhead wrote:
Have your wife (or girlfriend hold the secondary wire while you slowly rotate the engine. If she jumps at the same time you feel the detent in the cam gear, you are good to go.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 03-27-2019, 08:47 AM   #44
old31
Great idea but they wont be his wife or girl friend for very long.
Old 06-01-2019, 08:37 AM   #45
aermotor
Originally Posted by Tom Wesenberg View Post
You can raise the rotor higher by putting small cardboard pieces on top of the distributor shaft. This is easier than trying to bend the stiff brass. I don't recall seeing this problem.
I don't see why the rotor pin has to be on the same plan as the distributer pin as long as the closest points (gap) are .020.
John
aermotor is offline   Reply With Quote
Old 06-01-2019, 11:09 AM   #46
daveymc29
daveymc29's Avatar
Had my new bride hold the plug lead on a Graham Paige Rototiller ONCE, Still around after 60 odd years, won't look at a plug wire and asks no questions about "Why don't you do thus and such?"
daveymc29 is offline   Reply With Quote
Old 06-01-2019, 04:51 PM   #47
Dutie
Dutie's Avatar
I look in the pin hole with a super bright LED small flashlight reflecting off of a small 2x3 mirror with an extension. If positioned just right you can see the dimple on the gear clearly. Try it and good luck, let us know. Dutie
Dutie is offline   Reply With Quote
Old 06-01-2019, 06:44 PM   #48
Purdy Swoft
Purdy Swoft's Avatar
[QUOTE=40 Deluxe;1682127]So, after all this exacting effort to get the timing "exactly right", you start the engine and pull the spark lever down to where "that sounds about right"! Where is the timing at now? Don't know, do you![/QUOT
If the initial timing isn't accurately set , You really won't know where the timing is when you pull the spark down . If you don't know where the timing is when you retard the spark it can damage the starter when you try to crank it . If the timing is too advanced the engine will kick back and it still won't start . If a person thinks the problem is the battery and tries to hand crank the engine can kick back and break your arm if the timing is too advanced .This is a couple of reasons why exact initial timing is so important .
