Old 04-07-2012, 11:20 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Update on battery problem-for Lindy in Aurora
We checked every circuit today- both amps and voltage, and could find no draw at all. The battery has been charged back full, and we have pulled the fuse on the signal set up. It will sit for 2 weeks while I am away and see if the battery again discharges.
Also we have discovered that the crankshaft pulley is moving on the shaft-the keyway inside the pulley is apparently worn badly and allowing the pulley to move back and forth. The water pump fan blade was replaced because the inside tapered shaft opening was worn and allowing the fan to move.
Bob
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
