Old 04-07-2012, 07:08 PM   #1
leadpot
leadpot's Avatar
Default No Pressure to answer this question.
Hooked an oil pressure guage to my stock 29 tudor today. Know the A's oil pressure is fairly low but sufficient. After the installation I started it up cold & was quite pleased to see about 7lbs with a fast idle. Took it for a drive & within a half of a mile it dropped to zero. Even at 50 mph it was still zero. Is this normal or any cause for concern?
leadpot is offline   Reply With Quote
Old 04-07-2012, 07:40 PM   #2
ctlikon0712
ctlikon0712's Avatar
Default Re: No Pressure to answer this question.
Mine is the same and that is normal. See this older thread for a confirmation. If you kit came with a small 1/8" od line try replacing it with adapters to go to a 1/8" ID copper or Steel braded and the gage will read with better resolution. Some say copper is a bad idea but that's up to you. Good luck!
https://www.fordbarn.com/forum/showth...w+oil+pressure
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 04-07-2012, 07:45 PM   #3
IrishHills
IrishHills's Avatar
It wouldn't have been a concern if you hadn't installed the gage.
yea I know, not much help.
IrishHills is offline   Reply With Quote
Old 04-07-2012, 07:56 PM   #4
Paul from Maine
Paul from Maine's Avatar
If the lack of oil pressure is making you nervous, switch to a synthetic oil. Now that I have changed from straight 30 weight to Mobil 1, I show a pound or two of pressure when hot. Before when hot, I only saw oil pressure above thirtyfive mph. As the bearings don't need pressure, just flow, your 7 lbs at start up show everything is working fine.
Paul from Maine is offline   Reply With Quote
Old 04-07-2012, 08:07 PM   #5
glenn in camino
glenn in camino's Avatar
That guage probably raises your blood pressure more than it helps your engine.
glenn in camino is offline   Reply With Quote
Old 04-07-2012, 08:13 PM   #6
Aerocraft
Aerocraft's Avatar
Remember, the oil system is not "capped" and is high volume, low pressure. I describe the system as a oil delivery, not a pressure system. There is no direct link in the system to the main or camshaft bearings, it is all gravity feed from the valve chamber. If you are concerned about having enough oil flowing through the system, take off the side casting covering the right side of the cam gear and run the engine. A few of us in our local club recently did that. Be prepared for a flood.
I recently bought a Model A powered Pietenpol airplane that had an engine "condemned" by an aviation mechanic due to the engine having "lost" oil pressure when hot in addition to having several stuck valves. The owner would not believe me when I explained that no oil pressure is OK. As Glenn said, don't worry about oil pressure!
Gar Williams
Aerocraft is offline   Reply With Quote
Old 04-07-2012, 10:19 PM   #7
leadpot
leadpot's Avatar
Thanks for all the comments especially the one from Mr Bill. Confirms what I suspected since there has been no problem with the car. Did use 1/8" copper line & why is this a bad idea? Figured copper would be better than a plastic line that could easily melt.
Thanks Again,
Old 04-07-2012, 10:40 PM   #8
ctlikon0712
Some say the copper line will fatigue from vibration and heat over time and crack. That is why its not used on Brake or Fuel lines. I think its better than the Plastic or nylon one that comes with the kit.
Old 04-08-2012, 12:06 AM   #9
RHD
RHD's Avatar
It is best not to have an oil pressure gauge at all. What you don't know want worry you.
R.H.D.
Author of Model 'A' Ford technical manuals.
Supplier of good original RHD parts.
RHD is offline   Reply With Quote
Old 04-08-2012, 03:24 AM   #10
pooch
pooch's Avatar
Yeh, what the eye don't see the heart don't grieve about.....
pooch is offline   Reply With Quote
Old 04-08-2012, 03:32 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Great analogy!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
