Old 04-03-2015, 07:21 PM   #1
loubob
Default Spare Tire Bolts
These bolts are supposed to be swedged on to the rear mount tire bracket.
These special bolts have a square shoulder built in to them.
The original bolts square shoulder is 1/4"-5/16" in depth.
The bolts from Snyders, Brattons, & Macs are only 3/16" and they cannot be swedged.
Does anyone know where the correct bolts can be obtained?
Thanks.
loubob is offline   Reply With Quote
Old 04-03-2015, 10:41 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Spare Tire Bolts
Originally Posted by 1930 coupe View Post
If any parts cannot be found from any vendor, the next step is go to your garage and make one on your lathe and mill or go to your local machine shop and have one made.
Here in South Florida machine shop rates are about 60.00 an hour, one hour minimum. I went to several figuring it would be easier and faster to have them fix the ball on the shifter, just weld and grind. Was quoted between 120- 150 dollars. Must be cheaper where you live.
Old 04-04-2015, 04:40 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I found the complete spare mount at a swap meet for $5 about 10 years ago.
Old 04-04-2015, 09:19 AM   #4
loubob
I appreciate the replies.
Machine shop route too expensive.
Have no equip to braze, weld, etc.
Tried the only # for A&L in Ct. I could find and it is a non working #.
Saw a complete one 4 sale on Ebay but would be $42+ IF I was the only bidder.
I will secure the bolts with the rear spare lock nuts.
Thank you again.
Bob H.
Old 04-04-2015, 11:33 AM   #5
DGNY
Epoxy?
DGNY is offline   Reply With Quote
Old 04-04-2015, 11:37 AM   #6
ursus
What kind of body is the mount for? Maybe somebody here has the complete unit for less than the EBay price. I have several for a 30-31 coupe/roadster.
