Old 10-18-2019, 10:59 AM   #1
ag32milner
Default Early V8 axle under Model A front end
First let me begin stating that this topic has been presented many times but I need assistance. I have 1935 front axle that I would like to install under a 1931 A and retain mechanical brakes. It is my understanding that 1932-34 spring perches are required to complete swap. Bob Drake has B-3032 perches for 1932's, I called their tech assistance and explained Plan A. I was informed that B-3032 would not work for my situation. Don't remember any "why nots". Any assistance will be greatly appreciated.
ag32milner
ag32milner is offline   Reply With Quote
Old 10-18-2019, 11:54 AM   #2
Jim Brierley
Default Re: Early V8 axle under Model A front end
Model A through '34 had the same center-to-center spring-perch distance, 1935 - '48 that distance was wider, so the spring perch on your '35 would be closer to the brake backing plate. You would also need a longer spring, and your shocks wouldn't line up properly. '32-'34 would be an easier route to take.
Old 10-18-2019, 03:53 PM   #3
walls
35 creates problems as stated, add modifying the wishbone to the list.
Basically, it’s not a direct swap.
If you use a 32-34 axle, I suggest using the spindles as well.
There’s not much room for the tie rod to clear the front crossmember and pan if you keep the model A spindles.
Although they can work, torching and bending the steering arms has to be just right.
Just my opinion.
walls is offline   Reply With Quote
Old 10-19-2019, 10:37 AM   #4
rotorwrench
rotorwrench's Avatar
The distance from the top of the axle I-beam to the bottom at the perch points also changed which would affect the fit up of the wishbone. Model A axles are still out there. I've purchased a lot of them looking for straighter ones than ones I had. It would be a lot easier to just replace it.
Old 10-19-2019, 07:14 PM   #5
Chris Haynes
Chris Haynes's Avatar
The V8 axle will drop your front end a bit if that is what you are looking for. Reverse the spring eyes for more drop.
You will need a 1/4" thick spacer for the wishbone as the V8 axle is thinner. Put the spacer on the bottom of the axle. Otherwise the tie rod will rub on the wishbone. I found 1/4" fender washers that work nicely after having the center hole enlarged.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-20-2019, 03:04 AM   #6
Randy in ca
Randy in ca's Avatar
Much of this is incorrect, in that 1935-36 axles are identical to 1933-34. The method of spring mounting differs between those years but there is no difference in the axles themselves. 1932 axles also share the same dimensions for wishbone attaching and kingpin holes but were made heavier overall. All 1932-36 axles are 1/4" smaller at the wishbone attaching point and a spacer is required here, as previously mentioned, if these axles are to be used with Model A wishbones attached.
Randy in ca is offline   Reply With Quote
Old 10-20-2019, 05:09 AM   #7
walls
Don’t know how I forgot this.. too much to remember
33-36 axles are all the same as Randy states.
I’d still suggest using 32 spindles over the model A.
One more thing, you’re going to need a bushing for the 32 spring perches to use with the Model A shackle
Old 10-20-2019, 11:31 AM   #8
Chris Haynes
I used the "A" spring perches as the later ones have no provision for shock mounting. Here you can see that I removed the mount for the mechanical brakes.
Notice the 1/4" spacer between the bottom of the Axle and the Wishbone.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-20-2019, 11:46 AM   #9
Chris Haynes
Here is my '33-'36 Axle, Posey reversed eye spring, '37-'41 Spindles.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-20-2019, 11:51 AM   #10
Jim Brierley
Randy and Walls could be right, I don't think so but could be wrong. Best to measure before taking things apart, to be sure. '32 axles came in 2 styles, heavy duty and standard. Not sure but think the heavy duty was mostly in trucks. The difference is obvious when looking at them.
Old 10-20-2019, 12:41 PM   #11
ursus
Chris Haynes: How did you get your tie rod to cross over above the wishbone? On a Model-A axle mounted with '37-'41 spindles the tie rod will pass below the wishbone. Did you have to bend the steering arms upward? Thanks!
