02-28-2014, 09:33 PM | #1 |
35 Ford 3w cpe radiator
New to the forum. Been on FordBarn for a few years.I started to restore my 35 Ford 3w cpe. I got a few surprises: had my radiator checked and tested, they said it is shot. Question is: should I get it fixed $725 or get one of the new aluminum ones $525? Does the aluminum ones do the job? Also, the roll down rear window drain panel is rotted/rusted away. Does anybody repop these panels? I plan on using a later flathead V-8, radial www tires, 40 juice brakes and 12V system. I live north of Hershey and use the 2 interstates to get around. Thanks in advance for any input. Tom
02-28-2014, 10:04 PM | #2 |
Re: 35 Ford 3w cpe radiator
Hi Tom,
Where do you live, north of Hershey. I am in Grantville. I have a '35 5 window (project) Have you checked with Middletown Radiator on rebuilding the original? I'm sure the core is pricey if it needs a new one. But he always treats me well there. Good luck Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
02-28-2014, 10:39 PM | #3 |
Tom...you might want to think about brake energizers or floaters.I installed them on my '36 and they work great!! Fifty some bucks.Cheap! It might take you an afternoon but it's time well spent.No fluid leaks. Gene
03-01-2014, 12:54 AM | #4 | |
yep, and the brakes will still work after sitting for awhile!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
03-01-2014, 07:29 PM | #5 |
I had my '35 5 Window coupe radiator re-cored and it cost $610...which I thought was outrageous....but it runs perfect and I am very happy with it. I would ask a local car club for info and shop around and fix the old one...in this year the radiator has tabs for the hood sides and other unique alignment points........if they are off a little it will be a mess fitting the hood, which is a MAJOR undertaking when everything is original to start with ....save the old one, you will not regret it. There is a guy in Colorado that was making replacement rear window drains...very expensive, but the only game in town...I will try to find his info.....he has posted one in the SWAP section on Ford barn a year plus ago.....Matt in Alameda
03-01-2014, 07:54 PM | #6 |
03-01-2014, 07:57 PM | #7 |
Mac's Antique Auto has them for $350....item# VM233A.....Matt in Alameda
03-03-2014, 10:46 PM | #8 |
Hi Zach, I live in Hazleton less than 1 hour up I-81 from Hershey. Thanks for the reference for the Middletown Radiator business. I'll give them a call to see what they do for me. Tom
03-03-2014, 10:58 PM | #9 |
Hi Matt, Thanks for your input towards my radiator and rear window drain pan. I called Mac's today and ordered a drain pan...(on back order). I will probably have my original radiator recored ($725). Thanks Tom
03-03-2014, 11:03 PM | #10 |
Hi Gene, Do you think the mechanical brakes are just as safe as juice brakes. These old car brakes are new to me...Tom
03-04-2014, 12:09 AM | #11 |
I think so Tom.Mine stops great! I can roll it down the driveway very slowly and skid the tires.Easy install too.Before I installed them a panic stop meant...ok, I'm gonna lose the grille.I really didn't want to alter the originality of the car,mechanical speaking.And didn't want to go through the expense of finding later model backing plates etc.plus the bloody knuckles.Fifty +bucks well spent.If you need some pointers or more info,I'm glad to help. Gene
03-04-2014, 12:16 AM | #12 |
I'll jump in and answer for Gene with a quote from Henry Ford: "The safety of steel from pedal to wheel."
I personally believe that many collector cars are better off with mechanical brakes rather than juice brakes due to extended storage damage to the cylinders. There's nothing permanent, nothing solid about juice brakes. Old Henry made a very valid point with that quote. But then, you've been lurking here for a few years and yet you're still gonna run radials, aluminum radiator and 12 volts, so might as well go for broke with juice brakes, most guys do that anyway without a second thought.
Alan |
03-04-2014, 07:18 AM | #13 |
There is an early 35 radiator with the large top tank and the later 35 with a small top tank. Early has the overflow tube down the side and the later has it on the front center. The radiator upper supports rods to the firewall (length) and the front lower vented shield (notch for the overflow tube) also changed due to the radiator changes.
03-04-2014, 08:25 AM | #14 |
Mechanical brakes will slide all 4 wheels if set up right. You need good wheel bearing seals so grease don't get on the shoes, no warn shaft, pedal or main shaft bushings. Good rod ends, straight rods, clevis's and clevis pins. There is a printed procedure to set up and adjust these brakes. One thing about mechanical brakes is there is no moisture damage to cylinders, leaks or loss of fluid under heavy foot pressure. Back in THE day when we were young after WWll it was well known these brakes didn't work to good after a lot of braking. This was from wheel bearing seals leaking grease and the linings were soaked. I drive all cars including modern ones staying a good distance from the car in front using the engine compression to slow down bumping the brakes slightly as I come to a stop. Following close in an old car or any car is inviting a damaged front end. G.M.
www.fordcollector.com |
03-04-2014, 12:16 PM | #15 |
If you decide to get a new Radiator I would get a copper/brass one. Aluminum radiators are fragle and easily damaged and only way to repair them if the need comes up is to pinch off the bad tube and apply epoxy and you have lost the use of that tube. Coolingis about the same for either. Only advantage is weight savings for the Aluminum radiator. |
03-04-2014, 02:13 PM | #16 | |
