02-10-2022, 08:33 AM | #21 |
Re: Model AA cyclinder compression
Lift the spark straps a quarter inch gap then crank. Should see nice blue snap on each one. If that is ok, pull a plug and check if its wet, you should see some moisture on the plug, but if too wet then you are flooded.
02-10-2022, 10:47 AM | #22 |
I agree with Fullrace. I bought three condensers from one of the vendors early last year and only one worked.
02-10-2022, 01:39 PM | #23 |
I haven't read all the responses, but, I agree that your problem is not compression related.
If you are getting fuel, dripping at the throat when choked then its probably ignition related. I recently went thru 5 new 'burn-proof' condensers before finding a good one. I buy a bunch of them at a time, have to. |
