Old 01-23-2015, 11:05 AM   #21
trainguy
trainguy's Avatar
Default Re: Big 2 barrel carb for my Merc.
Originally Posted by chuck stevens View Post
Phil, I have used a Rochester 2bbl on a Mercury manifold, on that 47 I had down at your place, works great. There are two sizes, early-late, the later one has good size throttle bores, should be enough for you big flattie. But nothing will run as good as your duce roadster! Chuck S.
Chuck thanks for the complement.Had th roadster out last week drove it quickly around the township and put it away till spring,to cold!Look forward to getting together at the bash.You are always welcome to ride with Chuck L and myself if you need a FlatHead fix!Phil
trainguy is offline   Reply With Quote
