03-25-2018, 05:37 PM | #21 | |
Re: 28 pickup rear spring
I've been thinking about your comment for the last few days and yes I can now see your point. thankyou. gary do you like my photo of my 28 pickup. woofa is the hound tied up to the spare wheel. |
03-25-2018, 05:37 PM | #22 |
03-25-2018, 05:42 PM | #23 |
03-25-2018, 07:02 PM | #24 |
Woofa, I assume you are referring to my sign off line "At a certain age.....
I've seen 80 year olds a fit as some 50 year olds. A "certain age" sneaks up on us all, just faster for some than others. You'll know when it catches up with you.
04-02-2018, 09:01 AM | #25 |
thankyou all for sharing your knowledge with me. I am greatful to you and to this very useful site. gary
06-26-2018, 12:26 PM | #26 | |
yep I've been thinking about that and I'm going to try it. I think I'll remove those post manufactured shockers. They have done nothing to improve the ride. It's no longer a paddock basher but travels on formed roads of which most are bitumen. thanks, gary
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
06-26-2018, 12:53 PM | #27 |
Woofa,
Here is Marco's spring chart it will help you determine which spring leaves to remove maybe! https://fordbarn.com/forum/showpost....05&postcount=1 Color codes help ID which leaves go where in spring pack. Make note in far right column that leaves vary in thickness depending upon which position they occupy! Last edited by Benson; 06-26-2018 at 01:09 PM. |
06-28-2018, 06:25 AM | #28 | |
mines been poor since I first picked up a pencil. It is only spell check that saves me from ridicule. gary
06-28-2018, 10:08 AM | #29 |
You must keep the same height of the spring at the center bolt after you remove any number leaves. Measure the height before you take it a part. Example if you take 2 leaves out you must add 2 short leaves to the bottom of the spring to retain the same original spring height.
From one of the leaves you removed cut an 8" piece/s to use on the bottom of your reconstructed spring. Good luck Sofield |
07-30-2018, 03:20 PM | #30 | |
Thanks Sofield. g
08-01-2018, 07:08 AM | #31 |
correct spelling is not a attribute or a prerequisite on the Ford Barn.
08-03-2018, 03:28 PM | #32 | |
I'm pleased about that. gary
