09-21-2018, 03:56 PM | #1 |
Possibly stupid question
Does the drive shaft pull out of the differential by taking the torque tube off? The illustrations I see make it look like it should but I'm not sure.
In other words do I need to take an axle and housing off to remove the drive shaft? |
09-21-2018, 04:04 PM | #2 |
Re: Possibly stupid question
Yes the torque tube needs to come off and then you need a special puller to get the drive shaft and pinion gear out of the pumpkin.
09-21-2018, 05:26 PM | #3 |
NOT a STUPID question has been answered. My question is why are you wanting to remove the drive shaft? One question leads to another question, we all learn from questions from many answers:-)
09-21-2018, 07:00 PM | #4 |
09-21-2018, 07:41 PM | #5 |
Adding to above; after you remove the driveshaft tube, if the driveshaft/ pinion bearing/race assembly almost fall out of the housing or pull out with little resistance, you have issues that need to be address before you worry about cutting down the driveshaft.
09-21-2018, 08:17 PM | #6 |
09-21-2018, 10:11 PM | #7 |
Whattau building??
09-22-2018, 07:40 AM | #8 |
Yes, you have to remove an axle housing, the pinion is held to the driveshaft with a nut inside, the pinion is on a taper with a keyway just like a hub drum assy
09-22-2018, 08:36 AM | #9 |
just curious, why you need to shorten and how are you going to do it?
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
09-22-2018, 10:48 AM | #10 |
no such thing as a stupid question
09-22-2018, 10:50 AM | #11 | |
I am either going to install an AA four speed or some other small tranny in the driveline. In any case I need to shorten the drive shaft. I'm not using the A bell housing so I can't replace it with the shallower AA one. |
09-23-2018, 11:01 AM | #12 |
Some say there's NO such thing as a STUPID QUESTION! YES, THE THERE ARE! You probably remember some, TOO!----SOME don't even get a REPLY!
Bill W.
09-23-2018, 04:13 PM | #13 |
One of my school teachers, a very decent fellow by the name of Ray Gurran said "don't be afraid to ask for there will be others that don't know as well".
I guess not only did they not know but lacked the courage to ask.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
09-23-2018, 06:38 PM | #14 |
They say a picture is worth a thousand words. Click on the address below, it should answer a lot of question. It helped me
https://www.brattons.com/media/wysiw...r-Apr-2012.pdf Last edited by lsr490; 09-23-2018 at 06:41 PM. Reason: url working this time |
09-24-2018, 10:00 AM | #15 | |
09-24-2018, 11:52 AM | #16 |
Illustration No 18..Ah-ha! Thank you.
09-24-2018, 12:01 PM | #17 |
Here is a tech article from Tom Endy that is very helpful for banjo rear ends.
http://www.santaanitaas.org/wp-conte...vised-2014.pdf John |
09-24-2018, 09:00 PM | #18 |
It is common practice to shorten the drive shaft to make room to install an over drive .
Brattons catalog has been my quick referance for technical info that can be hard to find elsewhere !!!!!!! |
09-25-2018, 09:12 AM | #19 |
09-25-2018, 11:04 AM | #20 |
I would think that the people that sell the overdrive would offer this service. It would depend on the brand of overdrive that would be used . I have seen drive shafts and torque tubes shortened to alter the wheel base on some speedsters . Resplineing the end of the driveshaft is usually required .
