10-29-2010, 09:47 PM | #1 |
54 Merc 256 intake fit a 54 Ford 239 Y block?
Can anybody tell me if a 1954 Mercury 256 Y block intake will fit a 1954 Ford 239 Y block? Some one told me that the angle of the heads were different?
BOSSY |
10-30-2010, 12:17 PM | #2 |
Re: 54 Merc 256 intake fit a 54 Ford 239 Y block?
I think that all of the Y block Ford/Merc engines are generally the same, The compression, valve size and combustion chamber varies as do the intake manifolds from a small single carb to single four barrels and/or multiple four barrels...
Bill
Bill.... 36 5 win cpe |
10-30-2010, 07:34 PM | #3 | |
The problems come in with the 55 manifolds as the ports are quite a bit bigger and there is a matching problem. |
