10-30-2010, 04:53 PM | #1 |
Need brake line help
Putting disc brakes on front of 50 F-1. I got master cylinder ,propotioning valve, and 2 residual valves 2 and 10 psi. Now to my question, The proportioning valve has 2 out ports for front brake lines so do I need 2 residual valves for the front or do I plug off 1 of the out ports , use one residual valve and then T to both front brakes? Probably A dumb question but dad always said the only dumb questions were the ones I asked. Jim
10-30-2010, 06:02 PM | #2 |
Re: Need brake line help
Stand-a-lone proportioning valves have NO outlets to the fronts, so it sounds like you have a d_ _m combo valve. Pitch it and get an adjustable prop valve, which goes to the rears only. You really should know what you are trying to plumb into your brake system.
IF the master is below the calipers, run one 2 lb residual to both, and a 10 lb’er to the rear drums, requardless of master location. |
10-30-2010, 06:58 PM | #3 |
dickspadaro.com |
