Old 10-28-2011, 08:09 PM   #1
Pa Joe
Pa Joe's Avatar
Default Rad question
Rad question, will a radiator from a 1928-29 A fit a 30-31A ?
Pa Joe is offline   Reply With Quote
Old 10-28-2011, 08:18 PM   #2
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: Rad question
No, it's entirely different. The 28/29 radiator shell and 30/31 hood won't line up
Barry B./ Ma. is offline   Reply With Quote
Old 10-28-2011, 08:27 PM   #3
Pa Joe
Pa Joe's Avatar
Thanks Barry
Old 10-29-2011, 06:49 AM   #4
James Rogers
James Rogers's Avatar
28/29 is 1 or 2" shorter and has a screw on cap while the 30/31 is a half twist also the top hose fitting is at a different angle. The 28/29 will fit the frame and line up correctly if you shim it up but the shells are not interchangeable.
James Rogers is offline   Reply With Quote
