07-21-2010, 05:40 PM | #1 |
Hub Puller
I am new to model As and would like opinions about different wheel pullers. The K R Wilson is the most expensive so I assume it's the best. I was wondering if I could get away with the cheaper styles. your thoughts would be appreciated. Joe
07-21-2010, 06:04 PM | #2 |
Re: Hub Puller
I use a 3 Arm puller that fastens to 3 lug bolts. It has a centering point that pushes on the end of the axle. It has never failed to loosen a hub and has never done any damage. I don't know the brand name.
I noticed the harder I work the luckier I get! |
07-21-2010, 06:36 PM | #3 |
Re: Hub Puller
Mushroomed or bent axles are expensive to replace. Get the kr puller.
07-21-2010, 07:03 PM | #4 |
Re: Hub Puller
Like I always did in my foolish youth, I cheaped out and bought a 3-arm puller; it was useless. I bought the KR Wilson tool and it has worked great every time.
Steve |
07-21-2010, 07:24 PM | #5 |
Re: Hub Puller
K R WILSON Puller;
All you have to do is to keep from screwing up one hub or axle and the K R W Tool has paid for itself. My Opinion. |
07-21-2010, 07:47 PM | #6 |
Re: Hub Puller
07-21-2010, 09:47 PM | #7 |
Re: Hub Puller
Thanks to all you guys. Joe
07-21-2010, 10:25 PM | #8 |
Re: Hub Puller
Be sure to remove the castle nut and spacer, then reinstall castle nut, reversed, and just on far enough to be even with the end of the axel; this will keep you from screwing up the end of the axel.
Ron |
07-22-2010, 12:26 AM | #9 |
Re: Hub Puller
before you buy one check with your parts store some have loaners, if no luck there check with your brake shop they may lend you one, i have the extra heavy 3 arm puller and i have never found a hub i couldnt get off, mine weights over 20#
07-22-2010, 05:40 AM | #10 |
Re: Hub Puller
We have a model A one here which is a forged steel cone which completely engulphes the hub. It bolts on with all 5 lug nuts . The centre has a large fine thread bolt , through the centre of that is a sliding bolt. You bolt the puller hard to the hub and wind the big outer nut up hard .You then bop the sliding bolt head .I normally heat the hub end with a propane/butane hand held torch for a few minutes and never had one I could not get off or damaged an axle end. Just curious as I always thought it was a USA Ford shop tool . I also have the one for the AA truck hub and these can be a bear to get off but the AA puller has not been defeated yet.Just wondered if you have these in USA or are these "Made in England" ???
John in a lovely sunny spells breezy England |
07-22-2010, 07:36 AM | #11 |
Re: Hub Puller
[QUOTE=forever4;48554]Since you are asking, no, you cannot get away with a cheaper style.
Use the KRW style. http://www.fordgarage.com/pages/KRWhubpuller.htm I fabricated a puller designed like the KRW puller using the pictures in the web-site above. If you have the facilities to do this you can have the satisfaction of making your own. Mine is available to use for free to all the members of our Model "A" Club. Don/WI Last edited by Don/WI; 01-31-2011 at 10:53 PM. Reason: The URL has changed from the one I had listed. The new one is shown. Thanks. Don/WI |
07-22-2010, 08:24 AM | #12 |
Re: Hub Puller
Mitchell Mfg that make the overdrives are making a puller similar to the KR Wilson style. You might look at that one.
07-22-2010, 09:29 AM | #13 |
Re: Hub Puller
I use a very heavy duty three arm puller in my automotive shop. ( it's not cheep ) Ford dealers used them back a long time ago. Also used them on Chrys. products . We use it on the newer front hubs on a lot of front drive cars. I have never had any problems or damage done. This is just my opinion. Bill
07-22-2010, 09:38 AM | #14 |
Re: Hub Puller
There is the "Old Timer's" trick for loosening the rear hubs.
That was of loosening the axel nut and driving the car around the block. To loosen the right side, you took all left turns and visa-versa. It might work. It's worth a shot ! MIKE |
07-22-2010, 09:56 AM | #15 |
Re: Hub Puller
Any chance your local Model A club has a KRW puller in the tools is loans? If not, why not?
Charlie Stephens |
07-22-2010, 10:13 AM | #16 |
Re: Hub Puller
All the better brand pullers of the period, like Snap-on, K R Wilson, and Plomb came with a screw-on cap for the axle threads to protect them better than the reversed nut can. This is usually lost over the decades, but you can make one by cutting down a cheap modern "knocker" type puller (only about 5 bucks) and drilling in a snall depression to center the puller ram.
On the 3-leggers...I once had to pull a VERY stuck Model A drum with one. It nicely illustrated the problem with this tool on a 5 1/2" circle...the drum SPLIT across the friction surface from the distortion of the pull. I assume the hub was permanently distorted, but didn't check...all of that was rusted junk enclosing a nice gear set. The sound when that thing split must have sent every dog in the neighborhood three feet into the air...same for the later BANG when the hub finally let go. Three-leggers were used, but as HUB pullers, not as pullers from the studs. Multiple tool companies sold Ford adapters for standard 3 leg pullers...these were lozenge shaped forgings with two lug studs OR bolt holes. The adaptor slipped into the hub slot on the Ford, and the puller attached to it with 2 legs. Pulled from the center like KRW, just a more awkward tool to assemble. |
07-22-2010, 11:45 AM | #17 |
Re: Hub Puller
same here KR why take a chance?
07-22-2010, 11:58 AM | #18 |
Re: Hub Puller
Thanks again guys. The reason I ask is I had a 40 coupe a few years ago that I couldn't get the hub off until I broke down and paid the 150 bucks for a KRW. BUT, I screwed up, I left it in the car. It's in N Dakota and I'm in Pa. Guess I'll have to bite the bullet and get another one. Joe
PS Back then I still had a devil of a time even with the KRW |
03-01-2011, 02:53 PM | #19 |
Re: Hub Puller
I was having a hell of a time with the KRW as well, and decided to make some adjustments to it. I now have an "enhanced" version of the KR Wilson hub puller that I now manufacture. Check it out here: http://vintageprecision.com/products...ers/index.html
03-02-2011, 12:47 PM | #20 | |
Re: Hub Puller
The improvement is a special thrust nut that goes on the threaded axle end to push against. In use, it will not rotate and distributes the thrust load into the axle without crushing the cotter pin hole or axle end. The threads are preserved for reassembly even when the hub is really stuck hard on the axle. This doesn’t happen all the time, but when a hub is really stuck hard on an axle, it can sound like a cannon fired when it breaks free and that often means ruined threads on the axle end when your done. http://vintageprecision.com/products...ers/index.html |
