08-13-2014, 09:06 AM | #1 |
Tod winfield/ weiand head
Tod, would you consider having Bill Stipe do some dyno testing on a combustion chamber design PRIOR to making a new head. How do they know the winfield is the better of the two. and is it the best that can be built. THE POWERS TO BE WOULD LIKE TO KNOW. HAVE FUN modelAtony tony white Lafayette, LA all the best to your new engine.
08-13-2014, 11:00 AM | #2 |
Re: Tod winfield/ weiand head
Does Bill have a dyno test site??? If so I would like to add it to my favorites list.
08-13-2014, 01:40 PM | #3 |
08-13-2014, 02:29 PM | #4 | |
Now only does Bill build engines, but he has his own dyno to test them on...how cool is that ! Just wish that I could have had him build a B for me ! That man is a perfectionist, IMO ! Based on everything that I've purchased from him..like works of art ! Too bad, for us, that he is retiring, but I got my last order in in time ! |
08-13-2014, 09:40 PM | #5 |
08-13-2014, 09:47 PM | #6 | |
08-14-2014, 01:01 AM | #7 | |
Not sure what is to become of his shop. Seem to remember something of him having a son ? Maybe follow in Bills footsteps,eh ! Last edited by hardtimes; 08-14-2014 at 01:03 AM. Reason: .......... |
08-14-2014, 06:08 AM | #8 | |
I have owner many different performance heads and tried many of them on the same engine with only the head changed Winfield Red original iron was always made the best power other heads I have tried include Winfield Yellow, Super Winfield ( dispite the name not as good as the orginals) Weiand, Cyclone, Thomas, Evans, Simonds This my opinion but almost every racer or engine builder I have spoken with who has tried different heads agrees the crows foot iron Winfield No1 |
08-14-2014, 07:17 AM | #9 | |
I sent you a PM. Tod |
08-14-2014, 10:25 AM | #10 |
My take on dyno testing the different heads would be to give an idea of what the actual horsepower increase would be. We've seen tests on other heads. Sure, the Winfield heads are good and have stated compression ratios and a great history in the past .
08-15-2014, 01:05 AM | #11 |
Yes, I'm with Purdy. The dyno testing would be nice to see hp as well as the torque numbers. I am looking forward to the new head/s.
Simplicity is the ultimate sophistication. L.D. I have 40 horses in the garage. Only feed them when I want to take them out. 31 Model A Tudor 55B Nick |
08-15-2014, 05:53 AM | #12 |
Well, this also begs the question; can the crows food designed be improved upon by twisting or plug location.
Bill has the capability to make just a flat plate on his CNC where he doesn't need to build/cast a complete head with water jackets just to test with. He also has the ability to grind a special camshaft that can compliment the chamber design of a new head. Personally I also think this would be money well spent to do some dyno work, even if it requires adding $50.00 to the price of each head and amortize it over 150-200 units. The only downside to this new head is it may drop the prices on some vintage / era aftermarket heads. I say go for it! |
08-15-2014, 11:07 AM | #13 |
Depending on price, I agree. I've seen a lot of good parts that were priced so high that the common man would say, just forget it. If the price is reasonably, more parts will sell and still make a profit, maybe more in the long run
08-15-2014, 11:36 AM | #14 |
Brent and Purdy, pricing is less an object than coming up with chamber designs and time to play with them. I can make various chamber designs with my casting system that will keep pricing down. Keep in mind that I am basically the one-stop-shop, having the capacity to model up designs, make patterns, make castings (iron or aluminum) and machine those castings. It would take much too long to explain what I can do and just how I would do it but I am used to doing things others do not do or cannot do because my 37 + years in the industry has brought me into contact with quite a bit of data that I can utilize to get where I need to be. But time is always the enemy.
The twisted chamber interests me. Tod |
08-15-2014, 12:38 PM | #15 |
Back in the late 90's Allan Wylie dyno'd 6 heads (on a Sun chassis dyno), the new Aluminum Winfield, Anderson, Weiand, Price, Brumfield and the a Model B head. Winfield out performed all of them developing 41% more hp, 18, over the the "B" head. The others made 30% more, give or take.
This was published in the January '98 secrets of speed. |
08-15-2014, 11:19 PM | #16 | |
Very interesting ! Do you know if pictures were published, showing the comb chambers shapes....that were tested ? if so, can you picture them here. For instance, was the 'new alum Winfield' the crows foot or the other one pictured here lately ? |
08-16-2014, 02:46 AM | #17 |
The new aluminum Winfield is not a crows foot. Some have ground the crows feet into
the head though and had a improvement. It must be an air flow thing. |
08-16-2014, 07:30 AM | #18 |
08-16-2014, 11:05 AM | #19 |
I'll scan the article this weekend and post it here.
08-16-2014, 02:59 PM | #20 |
The new Winfield pattern is underway. While machining model A and T heads today I finished some pattern CNC cutting and was able to install my head pattern fixturing along side of the next pattern I need to cut. I decided to fit the new Winfield pattern into the time frame of the pattern I have to make. It will probably be finished in a couple of weeks.
Tod |
