10-04-2013, 05:10 PM | #1 |
Radiator fit?
Fit is what I am ready to throw, actually. My 30 coupe radiator is not mounted level - it looks slightly tipped to one side. Also the shell doesn't fit quite right - previous owner drilled new holes on the lower mounting tangs, about 1/2" forward of the original, apparently because the shell won't fit tight against the lower half of the radiator.
I'm wondering if this is a repop radiator or if it's the wrong year, or perhaps it was rebuilt that way. It looks old, but I know that's not a reliable indicator. Wondering what I can do about it short of replacement. Thanks...
Owning an antique car is "start fixing one thing, find four other things that need fixing." Lather, rinse, repeat. |
10-04-2013, 05:12 PM | #2 |
Re: Radiator fit?
Here's a photo where you can see how the radiator is not mounted straight:
10-05-2013, 12:55 PM | #3 |
Re: Radiator fit?
Looks to me that the bumper is crooked?? Rad looks OK JMO
Paul in CT |
10-05-2013, 01:14 PM | #4 |
Re: Radiator fit?
10-05-2013, 01:35 PM | #5 |
Re: Radiator fit?
Frame out of wack?
10-05-2013, 04:04 PM | #6 |
Re: Radiator fit?
..Confused in NY
10-05-2013, 05:01 PM | #7 |
Re: Radiator fit?
If the frame is twisted the radiator won't sit right on the cross member. I could be the cause of all your problems,
10-05-2013, 06:05 PM | #8 |
Re: Radiator fit?
More pictures needed of the shell (close up), top and bottom. How does the hood fit at the radiator and at the cowl?? Does the door belt line line up??
Paul in CT |
10-05-2013, 06:31 PM | #9 | |
Re: Radiator fit?
But who am I to say, my right leg is shorter than my "good" leg, so, to me, straight things look krookedy & krookedy things look straight Folks are ALWAYS askin' me if their tail light stands are level??? Are thy "FUNNIN" me, or should I get TICKED OFF?? Bill W. (confused) (Huddy, loosen the 4 bolts that hold the bumper brackets to the frame, jack up the bumper until level & tighten the bolts, that works 90% of the time.)
10-05-2013, 06:41 PM | #10 | |
Re: Radiator fit?
the bumper brackets to frame are not adjustable. either the brackets are bent or the frame horn is ,maybe both just went thru this on lucy with uneven brackets one was bent.. the jobbers sell good replacements Last edited by Mitch//pa; 10-05-2013 at 06:48 PM. |
10-05-2013, 09:02 PM | #11 |
Re: Radiator fit?
My guess is that the front spring is sagged on the drivers side, this is common. The drivers side has the most weight on it usually. The rear spring could also be sagged. I installed new repro front spring in the coupe and the sedan and it leveled them up nicely. A sagging front spring can sometimes set up a shimmy in the front end.
10-05-2013, 09:14 PM | #12 | |
Re: Radiator fit?
10-05-2013, 09:26 PM | #13 | |
Re: Radiator fit?
Ed
10-05-2013, 09:45 PM | #14 |
Re: Radiator fit?
It won't hurt to drive it just like it is. I have heard that some have turned the spring around and solved the problem. I've heard of and tried loosening all four U bolt nuts and tightening the high side down first and more than the low side with varying success. I've cold rearched springs with success for a short time before it resagged. Its fairly common for unrestored original cars to lean slightly to the drivers side
10-05-2013, 11:08 PM | #15 |
Re: Radiator fit?
The reason I said "jack it level" is because I've seen old Model A's where the bumper bracket to frame bolts have run for years, slightly loose, & wallowed out the frame holes, thus allowing some adjustment.
My Buddy, Ted, bought a '29 Coupe with an even MORE krookedy bumper & it "adjusted" nicely! I don't just say "OFF THE WALL STUFF" to hear my head rattle! I KNOW the're not meant to be "adjusted"! Some cars DO have "funny" holes so they can be adjusted. I got half of my "LARNIN", WURKING IN A WRECKING YARD! In the U.K, they call them "BREAKING YARDS" They also call a SEMI, an Articulating Lorrie. Bill W.
10-05-2013, 11:21 PM | #16 |
Re: Radiator fit?
To answer your question about the bad fit of the shell on the rad. core, I've seen this happen with old, replacement cores where the top tank is too tall or some other oddball core is just not right up to Ford's original prints. It's usually one tank or the other is not right and hitting the shell. I've got one sitting right here in my barn. I hate to scrap it, but I don't know what else it's good for.
10-06-2013, 08:42 AM | #17 | |
Re: Radiator fit?
10-06-2013, 08:47 AM | #18 | |
Re: Radiator fit?
