05-16-2016, 03:12 PM | #1 |
Front motor mounts 32-36
How do I tell the year on the 32-36 mounts? I know there is a little differance on the angle where the hose goes on. Is there a cast no, on the mount? Thanks Walt
05-16-2016, 03:24 PM | #2 |
Re: Front motor mounts 32-36
some have cast number, some do not. I've got a pair of 33-34, and one has the cast number, the other does not. Of course, 32 is unique, and is easily identified just by looks. 35-36 could look similar to 33-34, and I can't help with visual features. Maybe deuce-lover? 32 is unique because 32 has the separate 'strut' for the motor mount, and there is NO mount built into the water inlet. 33-36 all have a motor mount built into the water inlet.
I think there is an exception for early 33. David G would be the one to address that. Last edited by bobH; 05-16-2016 at 03:35 PM. |
05-16-2016, 03:31 PM | #3 |
Here are 33-34 mounts, in case this helps any....
05-16-2016, 04:34 PM | #4 |
Here are the 35 and 36 engine mounts.
05-16-2016, 06:35 PM | #5 |
Great pic guys, I'll check mine tomorrow. Thanks. Walt
05-16-2016, 07:10 PM | #6 |
