Old 09-09-2019, 07:11 AM   #1
adileo
adileo's Avatar
Default Let me ask another way
Hi Guys
I posted a question regarding an issue with my LED tail lights not working properly (head lights on no brake lights) and received no response.
Seeking to understand, how does regular/stock filament tail lights work on a 39?
Does the lower filament work the turn signals and stop lights and the upper filament work when the headlights are turned on? Or visa versa? Or something else?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 09-09-2019, 07:27 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Let me ask another way
The regular original bulb if you look close has a filament made of thin wire, that is taillight, the one that is the thicker wire will be the brightest, and for brake light
My friend has a 36 packard, it came with every type of bulb, all were dim, only getting 4.5 volts to taillight. Traced it to rusted nuts on the ammeter ---
Old 09-09-2019, 08:44 AM   #3
uncle buck
uncle buck's Avatar
My guess is the LED tail light bulbs are for 6V negative ground. I bought some last year for my 32 pickup and they would work with negative ground and not positive. There was a lengthy thread going and it had some info on why they won't work both ways
uncle buck is offline   Reply With Quote
Old 09-09-2019, 08:49 AM   #4
hook00pad
You might try switching the polarity to the rear bulbs. LEDs only work when wired in one polarity direction. That is the nature of a diode.
Al Hook
hook00pad is offline   Reply With Quote
Old 09-09-2019, 08:57 AM   #5
adileo
adileo's Avatar
Thx the LEDs are pos grd. They state that on the box they came in.
Thanks
Andy
1952 F1
Old 09-09-2019, 09:07 AM   #6
JSeery
JSeery's Avatar
I'm not familiar with the LEDs that are setup for Pos ground. Goes the socket or the harness part you removed have anything to do with the LEDs functioning in a Pos ground system?
On an incandescent bulb there is a difference in the filaments which ends up making one brighter than the other (the brighter one being the brake). But if they were connect backward it would still work, it would just have the brake light being dimmer than the tail light. It is just a brightness issue, not a function issue. The bulb filaments do have to provide enough load for a heat type blinker canister to work. But with LEDs you are going to have to have a compatible canister and/or a load device in the light unit.
Old 09-09-2019, 09:21 AM   #7
adileo
adileo's Avatar
Your right again. I had to put a resistor in-line then to grd to make led blink.
These are plug and play leds. I had no brake lights (with no headlights and no & no brake lights w lights on) before cutting out the bucket and canister of leds
Now everything works except when headlights on I have no brake lights
Thanks
Andy
1952 F1
Old 09-09-2019, 10:27 AM   #8
40cpe
40cpe's Avatar
I would find the brake light wire at the tail light bucket and verify that it is hot when brakes are actuated, both with headlights on/off. Then verify that the brake light hot wire is connected to the brake light section of the LED light. As jSeery said above, if the tail light wire is connected to the brake light section of the LED cluster, you won't see when the less bright portion (tail light) is activated by the brake light switch.
Old 09-09-2019, 12:09 PM   #9
JSeery
JSeery's Avatar
Good advice.
Adileo, was mainly interested in if the wiring is basically original with the turn-signal wiring added on.
Old 09-09-2019, 12:18 PM   #10
adileo
adileo's Avatar
Jerry that’s correct wiring original add turn signals
Thanks
Andy
1952 F1
Old 09-09-2019, 12:56 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
Some turn signals get the brake light wire to the turn signal switch, when in turn mode the brake light wire is disconnected in the switch to that bulb so the signal will flash--- many times a xtra wire is run to right side, original wire for brake lights would be used for left side
Old 09-09-2019, 02:02 PM   #12
cmbrucew
cmbrucew's Avatar
Make good ground wires for the rear light housings.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-09-2019, 02:33 PM   #13
adileo
adileo's Avatar
Bruce
That’s already been cared for thanks
Thanks
Andy
1952 F1
Old 09-09-2019, 05:20 PM   #14
adileo
adileo's Avatar
All fixed thank you for all your advise. The wires were reversed from LEDs.
Simple stupid....
Thanks
Andy
1952 F1
Old 09-09-2019, 07:29 PM   #15
JSeery
JSeery's Avatar
But you figured it out and fixed it! Good job.
Old 09-09-2019, 07:54 PM   #16
Jersey Devil
Jersey Devil's Avatar
Good job Andy, had my tools ready.
Tom
Jersey Devil is offline   Reply With Quote
